Vesta subdomain ssl not accept - error 429
My domain is: resim.oddamoda.com
I ran this command: VESTA CP auto
It produced this output: Error: Let’s Encrypt new auth status 429
My web server is (include version): nginx php-fpm
The operating system my web server runs on is (include version): centos 7.5
My hosting provider, if applicable, is: hertzener
I can login to a root shell on my machine (yes or no, or I don’t know): yes login shell
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): vesta
Hi @eminkadioglu
your error says: You have already created 5 identical certificates.
Yep, checked your domain - there are these - https://check-your-website.server-daten.de/?q=resim.oddamoda.com#ct-logs
Let's Encrypt Authority X3 2019-08-28 2019-11-26 resim.oddamoda.com, www.resim.oddamoda.com - 2 entries duplicate nr. 5 next Letsencrypt certificate: 2019-09-01 09:28:20
Let's Encrypt Authority X3 2019-08-28 2019-11-26 resim.oddamoda.com, www.resim.oddamoda.com - 2 entries duplicate nr. 4
Let's Encrypt Authority X3 2019-08-26 2019-11-24 resim.oddamoda.com, www.resim.oddamoda.com - 2 entries duplicate nr. 3
Let's Encrypt Authority X3 2019-08-26 2019-11-24 resim.oddamoda.com, www.resim.oddamoda.com - 2 entries duplicate nr. 2
Let's Encrypt Authority X3 2019-08-25 2019-11-23 resim.oddamoda.com, www.resim.oddamoda.com - 2 entries duplicate nr. 1
Let's Encrypt Authority X3 2019-07-10 2019-10-08 resim.oddamoda.com, www.resim.oddamoda.com - 2 entries
So you have a new certificate, but you don't use it. Instead, you use a certificate with your other domain:
CN=m.caddebazaar.com
	08.07.2019
	06.10.2019
expires in 36 days
m.caddebazaar.com, www.m.caddebazaar.com - 2 entries
Check your vHost configuration in your VestaCP, so that the vHost uses the correct certificate.
@JuergenAuer
I just solved my problems with the help of your writings. Besides I ve learnt so many things thanks what you wrote to me. I m writing for the ones who experienc the same problems with Vesta. That is enough to apply “v-add-letsencrypt-domain oddamoda resim.oddamoda.com”
