My domain is: servicedesk.firsttechfs.co.za
I ran this command: certbot certonly
C:\Program Files (x86)\Certbot>certbot certonly
Saving debug log to C:\Certbot\log\letsencrypt.log
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
Please enter in your domain name(s) (comma and/or space separated) (Enter 'c'
to cancel): servicedesk.firsttechfs.co.za
Requesting a certificate for servicedesk.firsttechfs.co.za
http-01 challenge for servicedesk.firsttechfs.co.za
←[31mChallenge failed for domain servicedesk.firsttechfs.co.za←[0m
←[31mSome challenges have failed.←[0m
←[1m
←[0m - The following errors were reported by the server:
Domain: servicedesk.firsttechfs.co.za
Type: connection
Detail: Fetching
http://servicedesk.firsttechfs.co.za/.well-known/acme-challenge/OViq1T10DQa7w
V1wDWkk5o3YRNtyJUt9c9Fw0FGA-dc:
The operating system my web server runs on is (include version): Windows Server Standard 2012 R2
or certbot-auto --version
if you're using Certbot): certbot 1.14.0
