partes.tasiva.com
certbot certonly --manual -d partes.tasiva.com
*Saving debug log to /var/log/letsencrypt/letsencrypt.log
Renewing an existing certificate for partes.tasiva.com
Create a file containing just this data:
2qfFnnlvDmCRkDa-oHqP5wbHjRTC4A9mwtiVg9nxFy8.m31wQIF-q-gPSezTQWrOwz5sCDaehsR3XYOEDwZWcfs
http://partes.tasiva.com/.well-known/acme-challenge/2qfFnnlvDmCRkDa-oHqP5wbHjRTC4A9mwtiVg9nxFy8
Press Enter to Continue
Domain: partes.tasiva.com
Type: connection
Detail: 88.10.67.208: Fetching http://partes.tasiva.com/.well-known/acme-challenge/2qfFnnlvDmCRkDa-oHqP5wbHjRTC4A9mwtiVg9nxFy8: Timeout during connect (likely firewall problem)
Hint: The Certificate Authority failed to verify the manually created challenge files. Ensure that you created these in the correct location.
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.*
apache2 (2.11.0)
Debian 6.1.94-1
Dinahosting
Yes
I think not, but I’m not sure.
Certbot 2.11.0
Explanation:
When I execute the command certbot certonly --manual -d partes.tasiva.com and I create the file in the path it tells me, I can access the file from the internet. (From another computer)
But when I hit enter and Certbot tries to access the path I get the error I showed before. I don't understand why this happens, any idea? I've checked everything, from opening ports 80, 8080, 443, permissions problems... But nothing.
Hi @iker.iparraguirre, and welcome to the LE community forum :slight_smile:
That is usually exactly what it sounds like.
Are you running a local firewall?
Is that the correct IP [88.10.67.208]?
Is your site accessible from the Internet via HTTP [TCP port 80]?
Yes, I am using the UFW firewall, here are the rules I have set up:
*Status: active
To Action From
1194/udp ALLOW Anywhere
OpenSSH ALLOW Anywhere
8080 ALLOW Anywhere
3306 ALLOW Anywhere
3306/tcp ALLOW Anywhere
80 ALLOW Anywhere
443 ALLOW Anywhere
9194 ALLOW Anywhere
8086 ALLOW Anywhere
3001 ALLOW Anywhere
8000 ALLOW Anywhere
3000 ALLOW Anywhere
9090 ALLOW Anywhere
80/tcp ALLOW Anywhere
443/tcp ALLOW Anywhere
22/tcp ALLOW Anywhere
30500 ALLOW Anywhere
1194/udp (v6) ALLOW Anywhere (v6)
OpenSSH (v6) ALLOW Anywhere (v6)
8080 (v6) ALLOW Anywhere (v6)
3306 (v6) ALLOW Anywhere (v6)
3306/tcp (v6) ALLOW Anywhere (v6)
443 (v6) ALLOW Anywhere (v6)
9194 (v6) ALLOW Anywhere (v6)
8086 (v6) ALLOW Anywhere (v6)
3001 (v6) ALLOW Anywhere (v6)
8000 (v6) ALLOW Anywhere (v6)
3000 (v6) ALLOW Anywhere (v6)
9090 (v6) ALLOW Anywhere (v6)
80/tcp (v6) ALLOW Anywhere (v6)
443/tcp (v6) ALLOW Anywhere (v6)
22/tcp (v6) ALLOW Anywhere (v6)
30500 (v6) ALLOW Anywhere (v6)*
The IP Address is correct, I can see the certificate correctly as you can see in the image:
Can you also reach your site/IP from the Internet?
I can't:
curl -Ii http://partes.tasiva.com/.well-known/acme-challenge/Test_File-1234
curl: (28) Failed to connect to partes.tasiva.com port 80 after 130996 ms: Connection timed out
Yes, I can, I see the following if I run from my home computer (it's outside my company's network)
And if i run from my company computer i see the same:
HTTP/1.1 404 Not Found
Date: Mon, 23 Sep 2024 12:24:11 GMT
Server: Apache/2.4.61 (Debian)
Cache-Control: no-cache, private
hmm...
Is there any GEO-Location blocking?
Looks like it; one tool I tried could only connect from Spain, and not from anywhere else.
It could be, everything seems to indicate that yes, my company's external firewall is run by another company, I'll send them an email and I'll let you know what they tell me.
I just wrote an email to the company that manages our firewall to allow connections from anywhere in the world. I will let you know what they tell me.
You (and/or the people managing the network) may find this post useful, describing how and why Let's Encrypt checks from multiple places around the world to ensure that one actually controls a domain name as seen from everywhere.
I bring good news, the problem was what you told me, the firewall rules have been changed to allow connections from anywhere in the world and now I have obtained the certificates correctly. Thank you very much!
It was what you said, the rules have been changed to allow connections from anywhere in the world and I have been able to obtain the certificates correctly.
