https://server3.thu.media:7081/
sudo certbot certonly
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
Please enter in your domain name(s) (comma and/or space separated) (Enter 'c'
to cancel): server3.thu.media
http-01 challenge for server3.thu.media
Input the webroot for server3.thu.media: (Enter 'c' to cancel): /usr/local/lsws/Example/html
Challenge failed for domain server3.thu.media
Domain: server3.thu.media
Type: connection
Detail: Fetching
http://server3.thu.media/.well-known/acme-challenge/rsvPsf1TF2SOWHTk0puJU7PVp_cwSclkUBt_w129mBM:
OpenLiteSpeed 1.7.7
https://server3.thu.media:7080/
user:admin
password:123456
or certbot-auto --version
if you're using Certbot):
certbot 0.40.0
I guess the problem is that i start the web service in port 7081,so if you get server3.thu.media
,you can`t open it.
So i wonder how i can get the cert.
