My domain is: gate.cj.co.id
I ran this command: sudo certbot certonly --webroot -w /var/www/html -d gate.cj.co.id
Failed authorization procedure. gate.cj.co.id (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: During secondary validation: Fetching http://gate.cj.co.id/.well-known/acme-challenge/BxAW3uTq_-VJjNEBZaA1Zr8cbrvshY7x1KSN9r_vqDY: Timeout during connect (likely firewall problem)
    Domain: gate.cj.co.id
    Type: connection
    Detail: During secondary validation: Fetching
My web server is (include version): Apache 2.4
The operating system my web server runs on is (include version): Ubuntu Server 18.04
My hosting provider, if applicable, is: VPS
Hi @al_zain92
"During secondary validation" is important.
Read
Letsencrypt checks your domain from different networks.
The error says: The main Letsencrypt servers are able to connect your domain. The additional servers are blocked.
May be you block some ip addresses or you have some regional filters.
I did’nt block some IP, before I also disasable ufw but still got error.
I use dedicated server and IP from provider
Cloud you tell how to check whether my ip accessable from letsencrypt server?
Btw I tried using staging environment successful
