demo.lomin.ai
certbot-auto certonly --manual
Press Enter to Continue
Waiting for verification…
Failed authorization procedure. demo.lomin.ai (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://demo.lomin.ai/.well-known/acme-challenge/EWbLNaAWwRZGM1UCqSvbIIxFFaoH09wPUEwVuYucCb0: Timeout during connect (likely firewall problem)
    Domain: demo.lomin.ai
    Type: connection
    Detail: Fetching
  • Your account credentials have been saved in your Certbot
nginx version: nginx/1.13.12
PRETTY_NAME=“Debian GNU/Linux 9 (stretch)”
NAME=“Debian GNU/Linux”
VERSION_ID=“9”
VERSION=“9 (stretch)”
ID=debian
AWS route 53.
yes.
no
Hello all!
I’m using Docker env with exposed 80, 443 port.
And I tested standalone and nginx plugin command for certbot.
But all of them doesn’t work for me.
So I tried with --manual option for debug.
As i understand certbot wants me to make url like “http://demo.lomin.ai/.well-known/acme-challenge/HHv-e7A6inc_lGwWqyfrzBfEZRm2LlLHWsIbpEDaEEw” to response ‘HHv-e7A6inc_lGwWqyfrzBfEZRm2LlLHWsIbpEDaEEw.9QWlxiDYoLlCDmfW3iNIOr5c9QYGGyBwfEZdCELrlKo’.
So I make the url with the key even I can access by myself.
But the http-01 challenge is not possible to me…
Anybody have idea to solve it?
Hi @Sangkwun
checked your domain online there are only timeouts (via demo.lomin.ai - Make your website better - DNS, redirects, mixed content, certificates ):
• http://demo.lomin.ai/
147.46.238.11 -14 10.023 T
Timeout - The operation has timed out
• https://demo.lomin.ai/
147.46.238.11 -14 10.030 T
• http://demo.lomin.ai/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
147.46.238.11 -14 10.027 T
So it's impossible to Letsencrypt to check your file. Your site is invisible.
Uhm.. Thanks for letting me to know clue for error.
I can access webpage via browser.
what's the difference between the test and normal access?
Below is my nginx part for 80port.
listen 80;
listen [::]:80;
server_name demo.lomin.ai;
location /.well-known {
    root /app/static;
    #return 200;
    return 301 https://$server_name$request_uri;
I can’t access your site in a browser either. Are you accessing it from the same network that it’s hosted on? Maybe your firewall is blocking external traffic?
With my browser I have the same result. But browsers are sometimes terrible to check such things. Browsers save redirects and Strict-Transport-Security settings, so online tools are better. They start always fresh.
My ufw status result is like below.
uhm is it possible to cause of router setting?
Status: active
To                         Action      From
Nginx Full                 ALLOW       Anywhere
22/tcp                     ALLOW       Anywhere
22                         ALLOW       Anywhere
80                         ALLOW       Anywhere
443                        ALLOW       Anywhere
Nginx Full (v6)            ALLOW       Anywhere (v6)
22/tcp (v6)                ALLOW       Anywhere (v6)
22 (v6)                    ALLOW       Anywhere (v6)
80 (v6)                    ALLOW       Anywhere (v6)
443 (v6)                   ALLOW       Anywhere (v6)
Oh as you said I can’t access the site via my smartphone!
I just accessed from same network from the server.
Is there any thing to solve it?
The ufw settings look fine. Yes, it could possibly be a router setting. Is the router configured to forward those ports to the web server? You need at least port 80 for validation and port 443 to actually serve HTTPS.
:grin:
I find the reason of problem…
I’m running server in university but the ports are not opened…
Thank you for all of you guys.
I need to open these ports first.
