DigitalOcean Droplet Certbot - Timeout during connect (likely firewall problem)
My domain is: archie.info
I ran this command: certbot certonly --force-renewal -d archie.info
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
http-01 challenge for archie.info
Challenge failed for domain archie.info
    Domain: archie.info
    Type: connection
    Detail: 146.190.0.227: Fetching
    http://archie.info/.well-known/acme-challenge/Oy0xCwjSxtIh7V6i_Mpq7Nrned3Tx0J7MZm4-Pv7Qs8:
Ubuntu 20.04 (LTS) x64
DigitalOcean
Yes
No
certbot 0.40.0
I made sure nothing is running on port 80. I ran the command and select option 1 to spin up temporary webserver. It sounds like it's not connecting for some reason.
I have these DNS type setup. It seems to work if I run a dockerized nginx on localhost and I go to the domain.
CNAME www.archie.info
A archie.info directs to 146.190.0.227
NS ns1.digitalocean.com. to ns3
Welcome to the community @archie824
First, --force-renewal won't fix problems. It often causes Rate Limit problems so you should not use that.
For better debugging of stand-alone you should try this:
certbot certonly --standalone -d archie.info --debug-challenge -v
It will show you the URL that will be requested by the Let's Encrypt server. And, will pause so you can try the URL yourself. Just make sure to try it from the public internet.
root@archieinfo-main-ubuntu:/archieinfo# sudo certbot certonly --standalone -d archie.info --debug-challenge -v
Root logging level set at 10
Requested authenticator standalone and installer None
Single candidate plugin: * standalone
Description: Spin up a temporary webserver
Entry point: standalone = certbot.plugins.standalone:Authenticator
Initialized: <certbot.plugins.standalone.Authenticator object at 0x7f8e0cf116a0>
Prep: True
Selected authenticator <certbot.plugins.standalone.Authenticator object at 0x7f8e0cf116a0> and installer None
Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-v02.api.letsencrypt.org/acme/acct/550238166', new_authzr_uri=None, terms_of_service=None), 0c82c17d39cd55fc228a80fddc47d21d, Meta(creation_dt=datetime.datetime(2022, 5, 19, 6, 33, 48, tzinfo=), creation_host='archieinfo-main-ubuntu'))>
Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 658
Received response:
HTTP 200
Server: nginx
Date: Thu, 19 May 2022 19:11:23 GMT
Content-Length: 658
X-Frame-Options: DENY
"meta": {
"caaIdentities": [
"letsencrypt.org"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf",
"revokeCert": "https://acme-v02.api.letsencrypt.org/acme/revoke-cert",
"tLh42eOu2G8": "Adding random entries to the directory"
Generating key (2048 bits): /etc/letsencrypt/keys/0007_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0007_csr-certbot.pem
Requesting fresh nonce
Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
Received response:
HTTP 200
Server: nginx
Date: Thu, 19 May 2022 19:11:24 GMT
Link: https://acme-v02.api.letsencrypt.org/directory;rel="index"
Replay-Nonce: 0102mUmTk-fe4oReD6MH4bnaZ-kqC0EDRsgUHrYdGhjoPQU
Storing nonce: 0102mUmTk-fe4oReD6MH4bnaZ-kqC0EDRsgUHrYdGhjoPQU
JWS payload:
b'{\n "identifiers": [\n {\n "type": "dns",\n "value": "archie.info"\n }\n ]\n}'
Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNTUwMjM4MTY2IiwgIm5vbmNlIjogIjAxMDJtVW1Uay1mZTRvUmVENk1INGJuYVota3FDMEVEUnNnVUhyWWRHaGpvUFFVIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9uZXctb3JkZXIifQ",
"signature": "vuVWbSjX2KtfAZYo69OHNF9YGOvtnKRaz8-__85qMPfHNRN050C6PggcyzLbteCiVMw3i5uKFZoG5Hf4rwqPy4t-om_hwO6GXjTiVRXgDg1vKcE1NXjOb7vMZ9AgUwyFfbb6fM52fX47ayQb-7JFQbRN9aKhd9kJLsAjpm6LvKuAAg74TdXcTs6h19ctH0X4vLvHyNmUmlIvtX1rR-D3mIhG3GTehmiuscD9aNOlDJgLuTfyImgDVfhJON2YBu6KkaR3NNxXDfAczB5p0QQ2N5A7iHeChFx7DGIOg7vO_VfvnmM7M9lQdecbi2pjkp4P87bYJGs8Gn4N_MnExzmrEw",
"payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogImFyY2hpZS5pbmZvIgogICAgfQogIF0KfQ"
https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 335
Received response:
HTTP 201
Server: nginx
Content-Length: 335
Boulder-Requester: 550238166
Location: https://acme-v02.api.letsencrypt.org/acme/order/550238166/90121769246
Replay-Nonce: 0102OPofwyWdx0kzL5uY9CYMdFrns5HCqmGO4YYMYVPG7-w
"status": "pending",
"expires": "2022-05-26T19:11:24Z",
"identifiers": [
"type": "dns",
"authorizations": [
"https://acme-v02.api.letsencrypt.org/acme/authz-v3/110402200676"
"finalize": "https://acme-v02.api.letsencrypt.org/acme/finalize/550238166/90121769246"
Storing nonce: 0102OPofwyWdx0kzL5uY9CYMdFrns5HCqmGO4YYMYVPG7-w
JWS payload:
b''
Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/110402200676:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNTUwMjM4MTY2IiwgIm5vbmNlIjogIjAxMDJPUG9md3lXZHgwa3pMNXVZOUNZTWRGcm5zNUhDcW1HTzRZWU1ZVlBHNy13IiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My8xMTA0MDIyMDA2NzYifQ",
"signature": "QJ_t9R7YWafBZr056Wkz1Ylawr3QOptz__LdZ1qpPwfzOsVqlEm5eoBwigXkGvUtKAwtAKL94zynhxbDloyfP7fOgDoLpBBRMzfi_shxK-MF2_FqrAdQWpyxJtB7RHXpf4NNEH4cYuVdO8jXXTsKgpBjef4FHRM7LwYZSo0q5yX3BpKhVXJEkbaXck6m7bb5GHjXJbSXVlDVX2NyCThsMic-crFa8bM2KysEJ8AVZtHqw_-j4zQ7OF8ZjDBS39gi_nyfARfDpBTr6cqHfXlDQMRr_Wptdavybn_YO07xBi3r9p71e1CS9gULA5FAw4dEsloncwYDrqNx-zTVMhWr9g",
"payload": ""
https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/110402200676 HTTP/1.1" 200 795
Received response:
HTTP 200
Server: nginx
Content-Length: 795
Replay-Nonce: 0101zLjxeuwTM-0CSRDk1bL4Mlmkm0WhHIyI9MqbuCULrf0
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/110402200676/srf6zw",
"token": "UxvLVIjj3oK3VnjvI-Udavk_X6OP2y-IvXSMo58Q1eY"
"type": "dns-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/110402200676/fbJjPg",
"type": "tls-alpn-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/110402200676/gNYdNw",
Storing nonce: 0101zLjxeuwTM-0CSRDk1bL4Mlmkm0WhHIyI9MqbuCULrf0
Successfully bound to :80 using IPv6
Certbot wasn't able to bind to :80 using IPv4, this is often expected due to the dual stack nature of IPv6 socket implementations.
Challenges loaded. Press continue to submit to CA. Pass "-v" for more info about
challenges.
Press Enter to Continue
JWS payload:
b'{\n "resource": "challenge",\n "type": "http-01"\n}'
Sending POST request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/110402200676/srf6zw:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNTUwMjM4MTY2IiwgIm5vbmNlIjogIjAxMDF6TGp4ZXV3VE0tMENTUkRrMWJMNE1sbWttMFdoSEl5STlNcWJ1Q1VMcmYwIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9jaGFsbC12My8xMTA0MDIyMDA2NzYvc3JmNnp3In0",
"signature": "pVeIvZNF5WSLHuxyZSfcyZx8Ke4VIaSCuMq2yjjGwUKtGpfE37pASakfDIeaeExEOLk0L4CJEsiPeULDTjJmsJ-doDgO7rdiKXwj_fM4sPT6t-zJING-_J_H8aHsk4BvRJX_h0oR9Bm3YuU6B5f-D2jaZTIKyzTPEAmAzguFE-ckSrN1ympJlzQyRnA3WD1JhoosfNjAxVg-hwAfGGrgiQFEK4qFU8olxzuddqHlgTl82crz4ZFI50Bskr5OkkgDCicJS_A5uWXslsUTXAkYlYUldhNuZnn4jmGARhzmIyi7mj1S56XAJJiEWBrV0QavqK_Ki4w73aAY8XbKi41QCA",
"payload": "ewogICJyZXNvdXJjZSI6ICJjaGFsbGVuZ2UiLAogICJ0eXBlIjogImh0dHAtMDEiCn0"
https://acme-v02.api.letsencrypt.org:443 "POST /acme/chall-v3/110402200676/srf6zw HTTP/1.1" 200 187
Received response:
HTTP 200
Server: nginx
Date: Thu, 19 May 2022 19:12:16 GMT
Content-Length: 187
Link: https://acme-v02.api.letsencrypt.org/directory;rel="index", https://acme-v02.api.letsencrypt.org/acme/authz-v3/110402200676;rel="up"
Location: https://acme-v02.api.letsencrypt.org/acme/chall-v3/110402200676/srf6zw
Replay-Nonce: 0102Aj0FqRoUbMfUWsKLnFJDFRFTUyYvufY4bGmAot75Mos
"type": "http-01",
Storing nonce: 0102Aj0FqRoUbMfUWsKLnFJDFRFTUyYvufY4bGmAot75Mos
JWS payload:
b''
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNTUwMjM4MTY2IiwgIm5vbmNlIjogIjAxMDJBajBGcVJvVWJNZlVXc0tMbkZKREZSRlRVeVl2dWZZNGJHbUFvdDc1TW9zIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My8xMTA0MDIyMDA2NzYifQ",
"signature": "gsyFMpJ0kIXSMRTOnoBZcgGcg4496vuWhsTI0a7huOIjRzY1_Wx5u1crbu-2DURXxeXX2TQy2xvIk-x2ZzYmSVD1jUzAACxkbybwTpi2nmulP0jcXZYgzwzV1moFBaPsIAoV0i88g-uJYkHv9dKfEhdxFZec7jJmDAyc8g_Zy67Q-UcDpYeepCeU96RUb42E8LwBPg-maq5Dr8lNHx8oA9rvleOkdU79BAB80i4CRDI5sSRjTd1-tdgaM6cbVt6o-FxbzR7ORrGoc7c6Vt2epoUpGeZxHuqljQ9DhLm1AxhlINRE6X8jRjssAUcJny1_iJMQyzG1Wes3FYQmuQE7xw",
"payload": ""
Received response:
HTTP 200
Server: nginx
Date: Thu, 19 May 2022 19:12:17 GMT
Content-Length: 795
Replay-Nonce: 0102HzKoEpV-7lnpDFf7PQIDUMzJv46fkiV1dwtP9SeulfQ
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"type": "dns-01",
Storing nonce: 0102HzKoEpV-7lnpDFf7PQIDUMzJv46fkiV1dwtP9SeulfQ
JWS payload:
b''
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNTUwMjM4MTY2IiwgIm5vbmNlIjogIjAxMDJIektvRXBWLTdsbnBERmY3UFFJRFVNekp2NDZma2lWMWR3dFA5U2V1bGZRIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My8xMTA0MDIyMDA2NzYifQ",
"signature": "u883rdtL29VTa7DneW8FufV8yRMapCljAG78RY5mr9ur2fY0h6AQcchZTdCdk88mBa54RmZcua_teeWHGTgZHddxAI9HUFEfNEmOsGyFe-VugGnfH1Uw53Ax63myu-PXEsqonSuqwmB9fPSFBpn--Irm6BR6oGxL22x73wi94JIiuBcEP1xWSqEwQr5iXuxpZ1L1m46iKzbfjq4i4grFBnfk_3Xw-NpBWHvH9i98Xr1_eNZ9vmjMLKwOhDDvjrEBsS9kgIIcdqu1rF3pUTYqTECKfnERF_FrW_PKaGonJvkUW9HmKv91S8k4uRY3pubToOWRxsdoJl_I5EdF3LaVEg",
"payload": ""
Received response:
HTTP 200
Server: nginx
Date: Thu, 19 May 2022 19:12:20 GMT
Content-Length: 795
Replay-Nonce: 0102kXyiBQK-zqFLG2fCNpE1s5YSrVoVkKNcE-wf6Y_vkpQ
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"type": "dns-01",
Storing nonce: 0102kXyiBQK-zqFLG2fCNpE1s5YSrVoVkKNcE-wf6Y_vkpQ
JWS payload:
b''
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNTUwMjM4MTY2IiwgIm5vbmNlIjogIjAxMDJrWHlpQlFLLXpxRkxHMmZDTnBFMXM1WVNyVm9Wa0tOY0Utd2Y2WV92a3BRIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My8xMTA0MDIyMDA2NzYifQ",
"signature": "Y3fB1nYDw69yGJgO9-TPOZAd1EkC_26EZcOP_-0993E5-qdfqaV6F_XJZgCnsfmgCeR08UHfKqEwD7KusVYl3Hk8rT7QyCdfJHQT9Ne2Pfx3Xf5VoCbBsGmuKO0DiWtLVfCSNlSwSDNKKNdaO0Di_fQ3wv0znoBaBbOlY7tODCFTQZuEHgECKaN_jCRjWXmopmBIBgXeOcKgN6EhF123fWuyWU-160_6U-81wdPAn7gZC36AZoDXmkmr6P2NQt3jHu9-vSmwzNgURjw4wDgTi21JmVojLhyE1RZc1A0z3GA0HLdoFYD4TcvMpcVtEW83HM3xzFAkRkiAACiIynVhTg",
"payload": ""
Received response:
HTTP 200
Server: nginx
Date: Thu, 19 May 2022 19:12:23 GMT
Content-Length: 795
Replay-Nonce: 0101Cdg26rBNFgCWWOpt7DbM4q4GcfQYb-SpfaDXK8CA2vM
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"type": "dns-01",
Storing nonce: 0101Cdg26rBNFgCWWOpt7DbM4q4GcfQYb-SpfaDXK8CA2vM
JWS payload:
b''
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNTUwMjM4MTY2IiwgIm5vbmNlIjogIjAxMDFDZGcyNnJCTkZnQ1dXT3B0N0RiTTRxNEdjZlFZYi1TcGZhRFhLOENBMnZNIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My8xMTA0MDIyMDA2NzYifQ",
"signature": "1R94zIupkEYLGIobt5RLSTD7_xs8TSPRKiRjX9FwQu_nKVLJYNtcUmjOT1OFEeSITWsnxrRS2-zockoM6kWwOkc3b99Ykzjl5DhRcTU6mlSVsqIJVuo2cXbWzY3tpHESGMXg6zsbceTDfkRLkFzIcVnf2JdMlen6IBawmhCrxe6_1uqU1UAI_SRJNbvpz6l2dLYDqf34CVUbtMikax6k3JlYarBmLPwKqESeFZ_MxlNm_sDdn3KehUgJPBvhc3Aj34XN_uxCRlfRllYceHXhJ6wvALcaGsc6Ajjm_BwquRt9Yx-hDymEofnG7IgbYCF34nFIrFhei8J9hEzo3Eg9aw",
"payload": ""
https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/110402200676 HTTP/1.1" 200 1042
Received response:
HTTP 200
Server: nginx
Date: Thu, 19 May 2022 19:12:27 GMT
Content-Length: 1042
Replay-Nonce: 0101N7_CjAFHZdvlPCe6VQW58zBxFqzSqSm7k_JXXMSp_UI
"identifier": {
"type": "dns",
"status": "invalid",
"challenges": [
"type": "http-01",
"error": {
"type": "urn:ietf:params:acme:error:connection",
"detail": "146.190.0.227: Fetching http://archie.info/.well-known/acme-challenge/UxvLVIjj3oK3VnjvI-Udavk_X6OP2y-IvXSMo58Q1eY: Timeout during connect (likely firewall problem)",
"status": 400
"token": "UxvLVIjj3oK3VnjvI-Udavk_X6OP2y-IvXSMo58Q1eY",
"validationRecord": [
"url": "http://archie.info/.well-known/acme-challenge/UxvLVIjj3oK3VnjvI-Udavk_X6OP2y-IvXSMo58Q1eY",
"hostname": "archie.info",
"port": "80",
"addressesResolved": [
"146.190.0.227"
"addressUsed": "146.190.0.227"
"validated": "2022-05-19T19:12:16Z"
Storing nonce: 0101N7_CjAFHZdvlPCe6VQW58zBxFqzSqSm7k_JXXMSp_UI
Reporting to user: The following errors were reported by the server:
Domain: archie.info
Type: connection
Detail: 146.190.0.227: Fetching http://archie.info/.well-known/acme-challenge/UxvLVIjj3oK3VnjvI-Udavk_X6OP2y-IvXSMo58Q1eY: Timeout during connect (likely firewall problem)
To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address. Additionally, please check that your computer has a publicly routable IP address and that no firewalls are preventing the server from communicating with the client. If you're using the webroot plugin, you should also verify that you are serving files from the webroot path you provided.
Encountered exception:
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 91, in handle_authorizations
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 180, in _poll_authorizations
Calling registered functions
Stopping server at :::80...
Exiting abnormally:
File "/usr/bin/certbot", line 11, in
load_entry_point('certbot==0.40.0', 'console_scripts', 'certbot')()
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1382, in main
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1265, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File "/usr/lib/python3/dist-packages/certbot/main.py", line 121, in _get_and_save_cert
File "/usr/lib/python3/dist-packages/certbot/client.py", line 417, in obtain_and_enroll_certificate
File "/usr/lib/python3/dist-packages/certbot/client.py", line 348, in obtain_certificate
File "/usr/lib/python3/dist-packages/certbot/client.py", line 396, in _get_order_and_authorizations
authzr = self.auth_handler.handle_authorizations(orderr, best_effort)
    Domain: archie.info
    Type: connection
I feel like this might be a DNS issue?
Just tried adding IPv6 to AAAA and still same error.
Oh, sorry, that debug method is only available on current versions of certbot. I just saw you are on 0.40. Ubuntu 20 supports the snap install so you should probably install that. Instructions to install are here
Is there a reason you need standalone authentication?
And, you should only use AAAA if you have a working IPv6 system. What happens with this?
curl -6 ifconfig.co
Does that match what you just added as AAAA record?
I figured out the issue. sudo ufw disable
I forgot I had set that earlier when I was setting up. Thanks for your help Mike!
