My domain is: test.33.foh.house
I ran this command:docker compose -f docker-data/docker-compose.yml run --rm --entrypoint "
certbot -v certonly --webroot -w /var/www/certbot
$staging_arg
$email_arg
$domain_args
--rsa-key-size $rsa_key_size
--agree-tos
--force-renewal" certbot
It produced this output: the failing portion is this: 2024-04-10 20:04:28,761:DEBUG:acme.client:Storing nonce: JLFMYkWoixlQ2nDp1PzJ-n0JKbTQh1pCbchhrARkis0H4iO2TIY
2024-04-10 20:04:31,765:DEBUG:acme.client:JWS payload:
b''
2024-04-10 20:04:31,771:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/336931346037:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTY2MTc5Njg3NyIsICJub25jZSI6ICJKTEZNWWtXb2l4bFEybkRwMVB6Si1uMEpLYlRRaDFwQ2JjaGhyQVJraXMwSDRpTzJUSVkiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LXYzLzMzNjkzMTM0NjAzNyJ9",
"signature": "K0u8RSjvtUkIOvxvPA10Byiz3J1fe9hm3kMqgLMaOITHUPAguNXNDAgDkcT04kAeNSUc4IFoHYiZJyE1JFcXciR_P7KjZ_h7lkA1xrkhwpOmKhlVifQ4ANge9ws86M6QIges7_KXN2MIwvHvOEflre1IkSnNfTft8UznLLTrHyZZrDKYkiUMX-OVtdPyGf8_4FG5ODU8tDStwv7q2-e2PRqCXzPTqLW8zLAt51G2Py-2RMFXBFSUr5mvsAwURdGWvwGLxEf08No8Z8-A4XcXkXboF6Vz7zfMqMUBI7xhv31GKWhHYHcGftRcFCt0ik0bT2rkslCZOV1jT69WxTeBbz8qfg5-WB-fa5L_thWiiJgqoUQD53h5YebC0s3Nxy-as4mmKakg3YWxZ0N9bncaTrCUyAVu1XWHvYyyM6BcWNdMC2YaxWsARPdLON1ZvvqCSF59UKmtMYIhZNljNqb_WcSFF8x5GtmwvQtbDjFnF-FL8QIXhMZkwyrL5ayQWdON45EdmXYYxyj7QF5vffwHXi4IweGBouMJHMhDy8zCX_JqnWQx-fvsxVgqSLaaV1iTlYNhstI_ODdLIkce5i-50EiUO6FAMRCXMJV6fKIfCEdeDb0SsZEg6SCD5yTTfi5rzMKSdN2H1bwlWL4neAJ3Bf1IdeT06ogXC8Dc42u0pl4",
"payload": ""
2024-04-10 20:04:31,840:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/336931346037 HTTP/1.1" 200 1207
2024-04-10 20:04:31,840:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Wed, 10 Apr 2024 20:04:31 GMT
Content-Length: 1207
Boulder-Requester: 1661796877
Link: https://acme-v02.api.letsencrypt.org/directory;rel="index"
Replay-Nonce: Xs-N5fZgM0_ozZPHH7luboq3vvlTCmNSGBCvS8rnDhhgyMcQZRc
X-Frame-Options: DENY
"identifier": {
"type": "dns",
"value": "test.33.foh.house"
"status": "invalid",
"expires": "2024-04-17T20:04:18Z",
"challenges": [
"type": "http-01",
"error": {
"type": "urn:ietf:params:acme:error:connection",
"detail": "During secondary validation: 104.143.78.83: Fetching http://test.33.foh.house/.well-known/acme-challenge/tB5dl7_LERfVwg0yhJGTZgof4pA631_uyRUfSP65owY: Timeout during connect (likely firewall problem)",
"status": 400
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/336931346037/KGkwew",
"token": "tB5dl7_LERfVwg0yhJGTZgof4pA631_uyRUfSP65owY",
"validationRecord": [
"url": "http://test.33.foh.house/.well-known/acme-challenge/tB5dl7_LERfVwg0yhJGTZgof4pA631_uyRUfSP65owY",
"hostname": "test.33.foh.house",
"port": "80",
"addressesResolved": [
"104.143.78.83"
"addressUsed": "104.143.78.83",
"resolverAddrs": [
"A:10.1.12.81:31390",
"AAAA:10.1.12.88:20140"
"validated": "2024-04-10T20:04:18Z"
2024-04-10 20:04:31,841:DEBUG:acme.client:Storing nonce: Xs-N5fZgM0_ozZPHH7luboq3vvlTCmNSGBCvS8rnDhhgyMcQZRc
2024-04-10 20:04:31,841:INFO:certbot._internal.auth_handler:Challenge failed for domain test.33.foh.house
2024-04-10 20:04:31,841:INFO:certbot._internal.auth_handler:http-01 challenge for test.33.foh.house
2024-04-10 20:04:31,841:DEBUG:certbot._internal.display.obj:Notifying user:
Domain: test.33.foh.house
Type: connection
Detail: During secondary validation: 104.143.78.83: Fetching http://test.33.foh.house/.well-known/acme-challenge/tB5dl7_LERfVwg0yhJGTZgof4pA631_uyRUfSP65owY: Timeout during connect (likely firewall problem)
2024-04-10 20:04:31,842:DEBUG:certbot._internal.error_handler:Encountered exception:
File "/opt/certbot/src/certbot/certbot/_internal/auth_handler.py", line 108, in handle_authorizations
self._poll_authorizations(authzrs, max_retries, max_time_mins, best_effort)
File "/opt/certbot/src/certbot/certbot/_internal/auth_handler.py", line 212, in _poll_authorizations
2024-04-10 20:04:31,842:DEBUG:certbot._internal.error_handler:Calling registered functions
2024-04-10 20:04:31,842:INFO:certbot._internal.auth_handler:Cleaning up challenges
2024-04-10 20:04:31,842:DEBUG:certbot._internal.plugins.webroot:Removing /var/www/certbot/.well-known/acme-challenge/tB5dl7_LERfVwg0yhJGTZgof4pA631_uyRUfSP65owY
2024-04-10 20:04:31,842:DEBUG:certbot._internal.plugins.webroot:All challenges cleaned up
2024-04-10 20:04:31,842:DEBUG:certbot._internal.log:Exiting abnormally:
File "/usr/local/bin/certbot", line 33, in
sys.exit(load_entry_point('certbot', 'console_scripts', 'certbot')())
File "/opt/certbot/src/certbot/certbot/main.py", line 19, in main
File "/opt/certbot/src/certbot/certbot/_internal/main.py", line 1873, in main
File "/opt/certbot/src/certbot/certbot/_internal/main.py", line 1600, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File "/opt/certbot/src/certbot/certbot/_internal/main.py", line 143, in _get_and_save_cert
File "/opt/certbot/src/certbot/certbot/_internal/client.py", line 517, in obtain_and_enroll_certificate
File "/opt/certbot/src/certbot/certbot/_internal/client.py", line 428, in obtain_certificate
File "/opt/certbot/src/certbot/certbot/_internal/client.py", line 496, in _get_order_and_authorizations
2024-04-10 20:04:31,843:ERROR:certbot._internal.log:Some challenges have failed.
My web server is (include version): nginx 1.15-alpine docker container
The operating system my web server runs on is (include version): Ubuntu 22.04.3 LTS
My hosting provider, if applicable, is: NA
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Not sure it is from certbot/certbot image from docker hub
I've verified that the challenge file is created and accessible using curl while it is temporarily there. My nginx logs show successful requests to the challenge file and sometimes one unsuccessful request that looks like its trying to access the file with all lowercase and failing because the file has some uppercase. I have a test.html file in the challenge folder that I can access successfully through the browser. I can't find any reason for the failure but it is consistent.
