test.vpps.link
sudo certbot certonly --server https://acme-v02.api.letsencrypt.org/directory --apache -d test.vpps.link
http-01 challenge for test.vpps.link
Challenge failed for domain test.vpps.link
Server version: Apache/2.4.41 (Ubuntu)
Ubuntu 20.04
self hosting
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.40.0
Previously have been successful in creating certificates using the manual DNS verification.
Am able to access the verification folder from the outside i.e.
http://test.vpps.link/.well-known/acme-challenge/
Continue to get the timeout error when attempting http challenge. Help appreciated as spent hours on this and got locked out one time by too many cert attempts.
Virtual hosts file contents
< VirtualHost *:80>
ServerName test.vpps.link
ServerAlias test.vpps.link
    DocumentRoot /var/www/html/test.vpps.link
I can reach that hostname too.
Let's Encrypts validations are send through CDNs, I believe AWS? Are you perhaps blocking some IP address ranges, which might include some CDNs, such as AWS? Or perhaps have a firewall with regional blocking set up?
I can confirm that I am able to connect to http://test.vpps.link/.well-known/acme-challenge/test via my own browser yet when I try to connect via https://www.redirect-checker.org/ I get a timeout.
But https://downforeveryoneorjustme.com/test.vpps.link and Test.vpps.link - Is Test Down Right Now? say it's up.
So it seems it's a partial block, maybe regional or in some other way selective.
I concur. I'm pretty sure that redirect-checker is US-based though, like myself, so there seems to be a very picky filter indeed.
Can you try to contact your ISP and see if there are a regional firewall in place?
Or other firewall rules blocking specific ranges of IP address or something like that.
Or aliens...
:alien: :flying_saucer:
Thanks for all your tips that are consistently pointing to a block. The alien got me this time. I’m sure it is my router firewall as I have a custom group to block hackers hitting the mail server on the same machine. As I see entries in the postfix log I then enter that IP address if not valid addresses.
Since it is an IP block and not domain name, please advise of the IP range/s that may be used with AWS.
Thanks again, will let you know once I get certbot back in action.
Let's Encrypt doesn't publish any such list. See various threads about this topic:
https://community.letsencrypt.org/search?q=%22validation%20ip%20addresses%22
The answer is in the error message (likely firewall problem). Found the culprit in the router IP address black list. Problem solved. Thank you all for your comments.
