Timeout during connect (likely firewall problem) [FAQ, but not solvable]
My domain is: makotosakuraijp.freedynamicdns.net
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter ‘c’ to cancel): makotosakuraijp.freedynamicdns.net
http-01 challenge for makotosakuraijp.freedynamicdns.net
Enabled Apache rewrite module
Waiting for verification…
Failed authorization procedure. makotosakuraijp.freedynamicdns.net (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://makotosakuraijp.freedynamicdns.net/.well-known/acme-challenge/HTaGfVk3sJkIp5wg1716OkcxUM0CQhPifRga34_XilU: Timeout during connect (likely firewall problem)
    Domain: makotosakuraijp.freedynamicdns.net
    Type: connection
    Detail: Fetching
Apache/2.4.29 (Ubuntu)
Ubuntu5.0.0-23-generic #24~18.04.1-Ubuntu SMP Mon Jul 29 16:12:28 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
(On Windows 10 VMware Player)
Biglobe
no.
certbot 0.27.0
133.205.170.89 is the correct IP address?
Port 80 completely open? That is, if you have a (NAT) router, is it mapped to the correct internal IP address? Firewall open? VMWare portmap needed? Does your Internet Service Provider block incoming port 80?
133.205.170.89 is correct. Port 80 seems to be open. I tried to open the firewall of my server and the router as well. The DMZ is used.
" VMWare portmap needed?" is not understandable for me. I just “bridged” the network, which is NOT NAT.
ISP blocking is not verifiable, but could be possible…
Makoto Sakurai
Ph.D. in Science 2008 (UTokyo)
Actually, I once successfully installed the letsencrypt script. But now it does not work after reinstalling my Ubuntu / VMware.
Makoto
