Timeout during connect
Hello,
lodomusbcn.com
certbot --apache -d lodomusbcn.com,www.lodomusbcn.com
http-01 challenge for lodomusbcn.com
http-01 challenge for www.lodomusbcn.com
Failed authorization procedure. www.lodomusbcn.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.lodomusbcn.com/.well-known/acme-challenge/HBIRfOu0E__wsVfTklUo1kXN7NvFInazu-V3tGnNaDE: Timeout during connect (likely firewall problem)
   Domain: www.lodomusbcn.com
   Type:   connection
   Detail: Fetching
The operating system my web server runs on is (include version): Ubuntu 16.04
What to do? I disabled the firewall and I get the same error. It used to work a couple of months ago, just upgraded the certbot version.
Thank you
Hi @fernandoch,
The A record for your domain lodomusbcn.com points to 5.196.73.140 but your subdomain www.lodomusbcn.com points to another ip address 5.135.181.224. Are you sure the ip for www subdomain is the right one?.
Cheers,
sahsanu
They are the same, maybe they did not propagate yet…
I changed them like 3 hours ago.
Where are you checking them?
I'm asking directly to your authoritative name servers:
$ dig @dns1.registrar-servers.com lodomusbcn.com +short
5.196.73.140
$ dig @dns2.registrar-servers.com lodomusbcn.com +short
5.196.73.140
$ dig @dns1.registrar-servers.com www.lodomusbcn.com +short
5.135.181.224
$ dig @dns2.registrar-servers.com www.lodomusbcn.com +short
5.135.181.224
Well, maybe I just have to wait and it will work?
OK, it worked. I changed the TTL to 1 min and it updated.
I ran the certbot command again and all working!
Thank for the help.
