I have had this issue before Timeout during connect (likely firewall problem) Apache2 Ubunut 20.04 server
My domain is: Sturtz.ml
Certbot
Enter email address (used for urgent renewal and security notices)
(Enter 'c' to cancel): nate.sturtz@sturtz.ml
agree in order to register with the ACME server at
https://acme-v02.api.letsencrypt.org/directory
(A)gree/(C)ancel: A
Would you be willing, once your first certificate is successfully issued, to
share your email address with the Electronic Frontier Foundation, a founding
partner of the Let's Encrypt project and the non-profit organization that
develops Certbot? We'd like to send you email about our work encrypting the web,
EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: N
1: sturtz.ml
http-01 challenge for sturtz.ml
Enabled Apache rewrite module
Challenge failed for domain sturtz.ml
Domain: sturtz.ml
Type: connection
Detail: Fetching
http://sturtz.ml/.well-known/acme-challenge/nj60I2FThSOzVbNw2WB92yCGVFY4USLEXxciHDMSJOI:
Apache/2.4.41 (Ubuntu)
Ubuntu 20.04
Self hosting
Yes
No
certbot 1.7.0
