Can't run certbot on Apache (Timeout during connect (likely firewall problem))
next-it.pt
sudo certbot --apache -v
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: next-it.pt
2: www.next-it.pt
Certificate is due for renewal, auto-renewing...
Renewing an existing certificate for next-it.pt and www.next-it.pt
http-01 challenge for next-it.pt
http-01 challenge for www.next-it.pt
Challenge failed for domain www.next-it.pt
Challenge failed for domain next-it.pt
Domain: www.next-it.pt
Type: connection
Detail: 62.48.220.98: Fetching http://www.next-it.pt/.well-known/acme-challenge/7sYyjHfbI40i_EufRvbS7kKVeku5jG2gtukf0QVStcw: Timeout during connect (likely firewall problem)
Domain: next-it.pt
Type: connection
Detail: 62.48.220.98: Fetching http://next-it.pt/.well-known/acme-challenge/SCFfdv3ryLd1YqUXjKsBw0f98hmvmdfbvfe3wBMw5a8: Timeout during connect (likely firewall problem)
Server version: Apache/2.4.41 (Ubuntu)
Server built: 2023-01-23T18:36:09
Ubuntu 20.04.5 LTS
Yes
No.
certbot 1.32.2
Hi @joseraeiro, and welcome to the LE community forum :slight_smile:
Something has changed since the last certificate renewal/issuance.
curl -Ii www.next-it.pt
Hello @rg305,
Thank you for your reply.
And what can be done about it?
I'd start by checking the firewall:
@rg305 and what should I be searching in the Firewall? Do you know? Can you help?
Not much is getting into your domain
$ nmap -Pn www.next-it.pt
Host discovery disabled (-Pn). All addresses will be marked 'up' and scan times will be slower.
Starting Nmap 7.91 ( https://nmap.org ) at 2023-02-10 10:24 PST
Nmap scan report for www.next-it.pt (62.48.220.98)
Host is up (0.17s latency).
Not shown: 999 filtered ports
PORT    STATE  SERVICE
113/tcp closed ident
Nmap done: 1 IP address (1 host up) scanned in 16.56 seconds
This is not a firewall assistance forum.
Do you have a firewall?
Who manages it?
Let's take a step back [I take nothing for granted].
Please confirm the IP address, with:
curl ipconfig.io
Do apologize. I'll check it myself.
62.48.220.97
(ran from inside the server containing the website)
Yet https://dnsspy.io/scan/next-it.pt shows only
And nmap for that IPv4 Address
$ nmap -Pn 62.48.220.97
Starting Nmap 7.91 ( https://nmap.org ) at 2023-02-10 10:32 PST
Nmap scan report for 62.48.220.97
PORT    STATE  SERVICE
Nmap done: 1 IP address (1 host up) scanned in 13.44 seconds
Then I have to update my DNS records to point the A entry to 62.48.220.97?
So how's the website being served on port 443?
Maybe.
You have to do, whatever you have to do, to make sure the site works properly [via HTTP] before trying to secure it [using HTTP-01 authentication].
I asked for the manager to disable all the firewall rules for incoming connections, but same result.
And, apparently, 62.48.220.97 is the IP that the machine is using for outbound connections.
You should try using Let's Debug test site (link here). It tests the comms and other items
I also time-out trying to reach your domain or the IP you show.
Can you connect to that domain with HTTP from outside your own network? You could use a mobile phone with wifi off to use your carrier's network. Based on what we see that would fail.
You should consult with your network experts to resolve this.
Can you reach your site via HTTP from the Internet?
Please remember Let’s Encrypt offers Domain Validation (DV) certificates.
So whatever the domain name(s) map to for IP Addresses is what Let’s Encrypt must use for Domain Validation; the exception being the DNS-01 Challenge(which is based off of a DNS record).
I am able to navigate correctly to the site by using my cellphone with my carrier's network (both http://next-it.pt and https://next-it.pt are working)
Read above.
