not looking to disclosure so let's call it domain-xyz.com
certbot --apache
# sudo certbot --apache
1: domain-xyz.com
2: www.domain-xyz.com
Requesting a certificate for domain-xyz.com and www.domain-xyz.com
  Domain: domain-xyz.com
  Type:   connection
  Detail: 100.200.300.400: Fetching http://domain-xyz.com/.well-known/acme-challenge/dKUUKpTa0HO0jc8hybW8hpqc9-2JQ3tCXq8eFlE7LDo: Timeout during connect (likely firewall problem)
  Domain: www.domain-xyz.com
  Type:   connection
  Detail: 100.200.300.400: Fetching http://www.domain-xyz.com/.well-known/acme-challenge/XSvHzPbW8NScP7VUqQQMGRfiX39qY9GCAsg5z-eEV9s: Timeout during connect (likely firewall problem)
Server version: Apache/2.4.51 (AlmaLinux)
# cat /etc/os-release
NAME="AlmaLinux"
VERSION="9.0 (Emerald Puma)"
ID="almalinux"
ID_LIKE="rhel centos fedora"
VERSION_ID="9.0"
owned corporate datacenter
no
# certbot --version
certbot 1.29.0
=== Additional Info ===
VirtualHost configuration:
<VirtualHost *:80>
# ServerName domain-xyz.com
  ServerAlias domain-xyz.com www.domain-xyz.com
  DocumentRoot /var/www/sites/domain-xyz/public_html
# ServerName www.domain-xyz.com domain-xyz.com
  <Directory '/var/www/sites/domain-xyz/public_html'>
    Options -Indexes -MultiViews +SymLinksIfOwnerMatch
    AllowOverride All
    Require all granted
    DirectoryIndex index.php
  </Directory>
# # Other directives here
</VirtualHost>
And the .htaccess file:
# redirect domains to server directories
RewriteEngine On
#RewriteCond %{REQUEST_URI} !/\.well\-known/?.*
RewriteCond %{REQUEST_URI} !^/.well-known/acme-challenge [NC]
RewriteCond %{REQUEST_URI} !^/well-known/acme-challenge [NC]
RewriteCond %{HTTP_HOST} ^(www\.)?domain-xyz\.com$ [NC]
RewriteCond %{REQUEST_FILENAME} !/v1/
RewriteRule ^(.*)$ /2022/$1 [L]
If I curl from outside:
~ % curl -L http://www.domain-xyz.com/.well-known/acme-challenge/XSvHzPbW8NScP7VUqQQMGRfiX39qY9GCAsg5z-eEV9s
*   Trying 100.200.300.400:80...
* Connected to www.domain-xyz.com (100.200.300.400) port 80 (#0)
> GET /.well-known/acme-challenge/XSvHzPbW8NScP7VUqQQMGRfiX39qY9GCAsg5z-eEV9s HTTP/1.1
> Host: www.domain-xyz.com
> User-Agent: curl/7.79.1
> Accept: */*
* Mark bundle as not supporting multiuse
< HTTP/1.1 404 Not Found
< Date: Wed, 31 Aug 2022 13:52:09 GMT
< Server: Apache/2.4.51 (AlmaLinux) OpenSSL/3.0.1 mod_fcgid/2.3.9
< Content-Length: 196
< Content-Type: text/html; charset=iso-8859-1
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL was not found on this server.</p>
</body></html>
* Connection #0 to host www.domain-xyz.com left intact
however, if I
# touch .well-known/acme-challenge/XSvHzPbW8NScP7VUqQQMGRfiX39qY9GCAsg5z-eEV9s
and test again:
> Accept: */*
< HTTP/1.1 200 OK
< Date: Wed, 31 Aug 2022 14:08:46 GMT
< Last-Modified: Wed, 31 Aug 2022 14:08:40 GMT
< ETag: "0-5e78a08aef41e"
< Accept-Ranges: bytes
< Content-Length: 0
< Content-Type: text/plain; charset=UTF-8
I do have SELinux enabled, but,
I'm used to auditing and applying policies to selinux, so I've done that. Nothing comes across regarding any events related. I've even disabled dontaudit policy with semodule -DB and went bananas looking for a hit that wouldn't show.
Finally I've set selinux to permissive, but fails anyway. So I've disregarded it being the issue.
What it seems to me is that it simply isn't creating the secret for validation. There's no timeout problem, and I'm stuck.
Hello @maverickws, welcome to the Let's Encrypt community. :slightly_smiling_face:
is difficult for us to debug and help you with.
Thank you for assisting us in helping YOU!
This error is a "Timeout". Meaning the Let's Encrypt server could not reach your domain.
Your examples using curl showed a 404 and 200 response. Both of those were successful connects just with different reply. Neither is a timeout. Are you sure you were testing from outside your network?
The Let's Debug test site is often helpful to debug
Without further details there is not much to say. A timeout is most often a firewall issue
Dear Bruce, thank you for your quick response.
Aside from the domain, I have provided answer to every single point solicited.
I am getting an error from a token that isn't created. I kindly invite you to read my post, which is very thorough in provided information.
What userid and group own the file(s) and what permissions does the file(s) have?
What userid is trying to access the file(s)?
Also please see @MikeMcQ's response Timeout during connect (likely firewall problem) - #3 by MikeMcQ as well.
The apache plug-in creates a temporary location for challenge files. You can review the certbot log for these details. But, the error is a timeout - not a 404 Not Found
Why I ask is sometimes root's umask(1p) - Linux manual page is set to something that won't allow others to access the file(s).
I figured that could be the case but wasn't quite sure.
Ok it fails here too.
You asked about if I'm from outside the network, so the server has a public ip directly to its public interface but is behind firewalls. The server IP has been added to the public access list which allows port 80 and 443 to said servers and i can connect to it from outside.
Now, my IP may be whitelisted for some other rule and I'm starting to wonder if that would be the issue, however finding it strange as other servers on the same list are working correctly, +looking at the firewall logs I don't see any hit for port 80 or 443 being blocked. I'm looking for another more external jumpbox where I can test from.
allowlist is a better word choice
Or a cell phone with wifi turned off :slight_smile:
First things first: Happy Birthday!
Please call it something else, that is a (potential) real domain name.
Like: example.com
I like the IPv4+ range:
Once you have allowed the Internet to reach your server [at least for HTTP], you can then use HTTP-01 authentication.
If it still fails, then you might want to verify Apache hasn't allowed any name:port overlaps, with:
apachectl -t -D DUMP_VHOSTS
Yup :slight_smile: thought the phone it was, but when i connect to it as hotspot it automatically sends me via cell network no need to disable wifi.
Anyway, indeed it's timing out. Going to check on that. Cheers!
Are invalid values for an IPv4 Address.
No way, are they really?
Check here: IPv4 - Wikipedia(IPv4,the%20ARPANET%20in%20January%201983.
Max value is 255 for an IPv4 address field.
yeah it's rfc1918. you kind of missed the irony. obviously those octets aren't correct, it was an obfuscation. come on man, really.
edit actually 1918 is private allocation. i believe the correct one is 791.
Someone's sarcasm meter is borked - LOL
[a clearly bad attempt at one]
I did find it cool :slight_smile:
But we digress, now back to the [firewall] problem!
I would choose 666.666.666.666 devil.tld for the DNS A record. :rofl:
I wasn't even thinking about caring how obvious it looked. Actually was thinking the more obvious it was not correct, more obvious the obfuscation would be.
Taking 5 before diving in that firewall, drinking fluids and all. :joy:
