My domain is: test123domain.xyz
I ran this command: sudo certbot certonly --apache -v
ssl_module is statically linked but --apache-bin is missing; not disabling session tickets.
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: test123domain.xyz
2: www.test123domain.xyz
Requesting a certificate for test123domain.xyz
http-01 challenge for test123domain.xyz
Challenge failed for domain test123domain.xyz
Domain: test123domain.xyz
Type: connection
Detail: 104.171.54.23: Fetching http://test123domain.xyz/.well-known/acme-challenge/A7HAIjl23t7khlUDfm27Cp-q3oUfF_9Mup95LyH-E38: Timeout during connect (likely firewall problem)
My web server is (include version): Apache/2.4.58 (Unix) OpenSSL/3.2.1
The operating system my web server runs on is (include version): MacOS 14.1.2
My hosting provider, if applicable, is: self hosting
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
Apache is default install via brew, httpd.conf is lightly changed:
# This is the main Apache HTTP server configuration file.  It contains the
# configuration directives that give the server its instructions.
# See <URL:http://httpd.apache.org/docs/2.4/> for detailed information.
# In particular, see
# <URL:http://httpd.apache.org/docs/2.4/mod/directives.html>
# for a discussion of each configuration directive.
# Do NOT simply read the instructions in here without understanding
# what they do.  They're here only as hints or reminders.  If you are unsure
# consult the online docs. You have been warned.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path.  If the filenames do *not* begin
# with "/", the value of ServerRoot is prepended -- so "logs/access_log"
# with ServerRoot set to "/usr/local/apache2" will be interpreted by the
# server as "/usr/local/apache2/logs/access_log", whereas "/logs/access_log"
# will be interpreted as '/logs/access_log'.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# Do not add a slash at the end of the directory path.  If you point
# ServerRoot at a non-local disk, be sure to specify a local disk on the
# Mutex directive, if file-based mutexes are used.  If you wish to share the
# same ServerRoot for multiple httpd daemons, you will need to change at
# least PidFile.
ServerRoot "/usr/local/homebrew/opt/httpd"
# Mutex: Allows you to set the mutex mechanism and mutex file directory
# for individual mutexes, or change the global defaults
# Uncomment and change the directory if mutexes are file-based and the default
# mutex file directory is not on a local disk or is not appropriate for some
# other reason.
# Mutex default:/usr/local/homebrew/var/run/httpd
# Listen: Allows you to bind Apache to specific IP addresses and/or
# ports, instead of the default. See also the <VirtualHost>
# directive.
# Change this to Listen on specific IP addresses as shown below to
# prevent Apache from glomming onto all bound IP addresses.
#Listen 12.34.56.78:80
Listen 80
<VirtualHost *:80>
    ServerName test123domain.xyz
    ServerAlias www.test123domain.xyz
    DocumentRoot /usr/local/homebrew/var/www
    ErrorLog /var/log/apache2/error.log
    CustomLog /var/log/apache2/access.log combined
</VirtualHost>
Listen 443 https
<VirtualHost *:443>
        SSLEngine on
        SSLCertificateFile /Users/admin/Documents/cert.crt
        SSLCertificateKeyFile /Users/admin/Documents/private.key
    ErrorLog /var/log/apache2/ssl-error.log
    CustomLog /var/log/apache2/ssl-access.log combined
</VirtualHost>
# Dynamic Shared Object (DSO) Support
# To be able to use the functionality of a module which was built as a DSO you
# have to place corresponding `LoadModule' lines at this location so the
# directives contained in it are actually available _before_ they are used.
# Statically compiled modules (those listed by `httpd -l') do not need
# to be loaded here.
# Example:
# LoadModule foo_module modules/mod_foo.so
#LoadModule mpm_event_module lib/httpd/modules/mod_mpm_event.so
LoadModule mpm_prefork_module lib/httpd/modules/mod_mpm_prefork.so
#LoadModule mpm_worker_module lib/httpd/modules/mod_mpm_worker.so
LoadModule authn_file_module lib/httpd/modules/mod_authn_file.so
#LoadModule authn_dbm_module lib/httpd/modules/mod_authn_dbm.so
#LoadModule authn_anon_module lib/httpd/modules/mod_authn_anon.so
#LoadModule authn_dbd_module lib/httpd/modules/mod_authn_dbd.so
#LoadModule authn_socache_module lib/httpd/modules/mod_authn_socache.so
LoadModule authn_core_module lib/httpd/modules/mod_authn_core.so
LoadModule authz_host_module lib/httpd/modules/mod_authz_host.so
LoadModule authz_groupfile_module lib/httpd/modules/mod_authz_groupfile.so
LoadModule authz_user_module lib/httpd/modules/mod_authz_user.so
#LoadModule authz_dbm_module lib/httpd/modules/mod_authz_dbm.so
#LoadModule authz_owner_module lib/httpd/modules/mod_authz_owner.so
#LoadModule authz_dbd_module lib/httpd/modules/mod_authz_dbd.so
LoadModule authz_core_module lib/httpd/modules/mod_authz_core.so
#LoadModule authnz_fcgi_module lib/httpd/modules/mod_authnz_fcgi.so
LoadModule access_compat_module lib/httpd/modules/mod_access_compat.so
LoadModule auth_basic_module lib/httpd/modules/mod_auth_basic.so
#LoadModule auth_form_module lib/httpd/modules/mod_auth_form.so
#LoadModule auth_digest_module lib/httpd/modules/mod_auth_digest.so
#LoadModule allowmethods_module lib/httpd/modules/mod_allowmethods.so
#LoadModule file_cache_module lib/httpd/modules/mod_file_cache.so
#LoadModule cache_module lib/httpd/modules/mod_cache.so
#LoadModule cache_disk_module lib/httpd/modules/mod_cache_disk.so
#LoadModule cache_socache_module lib/httpd/modules/mod_cache_socache.so
#LoadModule socache_shmcb_module lib/httpd/modules/mod_socache_shmcb.so
#LoadModule socache_dbm_module lib/httpd/modules/mod_socache_dbm.so
#LoadModule socache_memcache_module lib/httpd/modules/mod_socache_memcache.so
#LoadModule socache_redis_module lib/httpd/modules/mod_socache_redis.so
#LoadModule watchdog_module lib/httpd/modules/mod_watchdog.so
#LoadModule macro_module lib/httpd/modules/mod_macro.so
#LoadModule dbd_module lib/httpd/modules/mod_dbd.so
#LoadModule dumpio_module lib/httpd/modules/mod_dumpio.so
#LoadModule echo_module lib/httpd/modules/mod_echo.so
#LoadModule buffer_module lib/httpd/modules/mod_buffer.so
#LoadModule data_module lib/httpd/modules/mod_data.so
#LoadModule ratelimit_module lib/httpd/modules/mod_ratelimit.so
LoadModule reqtimeout_module lib/httpd/modules/mod_reqtimeout.so
#LoadModule ext_filter_module lib/httpd/modules/mod_ext_filter.so
#LoadModule request_module lib/httpd/modules/mod_request.so
#LoadModule include_module lib/httpd/modules/mod_include.so
LoadModule filter_module lib/httpd/modules/mod_filter.so
#LoadModule reflector_module lib/httpd/modules/mod_reflector.so
#LoadModule substitute_module lib/httpd/modules/mod_substitute.so
#LoadModule sed_module lib/httpd/modules/mod_sed.so
#LoadModule charset_lite_module lib/httpd/modules/mod_charset_lite.so
#LoadModule deflate_module lib/httpd/modules/mod_deflate.so
#LoadModule xml2enc_module lib/httpd/modules/mod_xml2enc.so
#LoadModule proxy_html_module lib/httpd/modules/mod_proxy_html.so
#LoadModule brotli_module lib/httpd/modules/mod_brotli.so
LoadModule mime_module lib/httpd/modules/mod_mime.so
LoadModule log_config_module lib/httpd/modules/mod_log_config.so
#LoadModule log_debug_module lib/httpd/modules/mod_log_debug.so
#LoadModule log_forensic_module lib/httpd/modules/mod_log_forensic.so
#LoadModule logio_module lib/httpd/modules/mod_logio.so
LoadModule env_module lib/httpd/modules/mod_env.so
#LoadModule mime_magic_module lib/httpd/modules/mod_mime_magic.so
#LoadModule expires_module lib/httpd/modules/mod_expires.so
LoadModule headers_module lib/httpd/modules/mod_headers.so
#LoadModule usertrack_module lib/httpd/modules/mod_usertrack.so
#LoadModule unique_id_module lib/httpd/modules/mod_unique_id.so
LoadModule setenvif_module lib/httpd/modules/mod_setenvif.so
LoadModule version_module lib/httpd/modules/mod_version.so
#LoadModule remoteip_module lib/httpd/modules/mod_remoteip.so
#LoadModule proxy_module lib/httpd/modules/mod_proxy.so
#LoadModule proxy_connect_module lib/httpd/modules/mod_proxy_connect.so
#LoadModule proxy_ftp_module lib/httpd/modules/mod_proxy_ftp.so
#LoadModule proxy_http_module lib/httpd/modules/mod_proxy_http.so
#LoadModule proxy_fcgi_module lib/httpd/modules/mod_proxy_fcgi.so
#LoadModule proxy_scgi_module lib/httpd/modules/mod_proxy_scgi.so
#LoadModule proxy_uwsgi_module lib/httpd/modules/mod_proxy_uwsgi.so
#LoadModule proxy_fdpass_module lib/httpd/modules/mod_proxy_fdpass.so
#LoadModule proxy_wstunnel_module lib/httpd/modules/mod_proxy_wstunnel.so
#LoadModule proxy_ajp_module lib/httpd/modules/mod_proxy_ajp.so
#LoadModule proxy_balancer_module lib/httpd/modules/mod_proxy_balancer.so
#LoadModule proxy_express_module lib/httpd/modules/mod_proxy_express.so
#LoadModule proxy_hcheck_module lib/httpd/modules/mod_proxy_hcheck.so
#LoadModule session_module lib/httpd/modules/mod_session.so
#LoadModule session_cookie_module lib/httpd/modules/mod_session_cookie.so
#LoadModule session_crypto_module lib/httpd/modules/mod_session_crypto.so
#LoadModule session_dbd_module lib/httpd/modules/mod_session_dbd.so
#LoadModule slotmem_shm_module lib/httpd/modules/mod_slotmem_shm.so
#LoadModule slotmem_plain_module lib/httpd/modules/mod_slotmem_plain.so
LoadModule ssl_module lib/httpd/modules/mod_ssl.so
#LoadModule dialup_module lib/httpd/modules/mod_dialup.so
#LoadModule http2_module lib/httpd/modules/mod_http2.so
#LoadModule lbmethod_byrequests_module lib/httpd/modules/mod_lbmethod_byrequests.so
#LoadModule lbmethod_bytraffic_module lib/httpd/modules/mod_lbmethod_bytraffic.so
#LoadModule lbmethod_bybusyness_module lib/httpd/modules/mod_lbmethod_bybusyness.so
#LoadModule lbmethod_heartbeat_module lib/httpd/modules/mod_lbmethod_heartbeat.so
LoadModule unixd_module lib/httpd/modules/mod_unixd.so
#LoadModule heartbeat_module lib/httpd/modules/mod_heartbeat.so
#LoadModule heartmonitor_module lib/httpd/modules/mod_heartmonitor.so
#LoadModule dav_module lib/httpd/modules/mod_dav.so
LoadModule status_module lib/httpd/modules/mod_status.so
LoadModule autoindex_module lib/httpd/modules/mod_autoindex.so
#LoadModule asis_module lib/httpd/modules/mod_asis.so
#LoadModule info_module lib/httpd/modules/mod_info.so
#LoadModule suexec_module lib/httpd/modules/mod_suexec.so
<IfModule !mpm_prefork_module>
	#LoadModule cgid_module lib/httpd/modules/mod_cgid.so
</IfModule>
<IfModule mpm_prefork_module>
	#LoadModule cgi_module lib/httpd/modules/mod_cgi.so
</IfModule>
#LoadModule dav_fs_module lib/httpd/modules/mod_dav_fs.so
#LoadModule dav_lock_module lib/httpd/modules/mod_dav_lock.so
#LoadModule vhost_alias_module lib/httpd/modules/mod_vhost_alias.so
#LoadModule negotiation_module lib/httpd/modules/mod_negotiation.so
LoadModule dir_module lib/httpd/modules/mod_dir.so
#LoadModule actions_module lib/httpd/modules/mod_actions.so
#LoadModule speling_module lib/httpd/modules/mod_speling.so
#LoadModule userdir_module lib/httpd/modules/mod_userdir.so
LoadModule alias_module lib/httpd/modules/mod_alias.so
LoadModule rewrite_module lib/httpd/modules/mod_rewrite.so
<IfModule unixd_module>
# If you wish httpd to run as a different user or group, you must run
# httpd as root initially and it will switch.
# User/Group: The name (or #number) of the user/group to run httpd as.
# It is usually good practice to create a dedicated user and group for
# running httpd, as with most system services.
User _www
Group _www
</IfModule>
# 'Main' server configuration
# The directives in this section set up the values used by the 'main'
# server, which responds to any requests that aren't handled by a
# <VirtualHost> definition.  These values also provide defaults for
# any <VirtualHost> containers you may define later in the file.
# All of these directives may appear inside <VirtualHost> containers,
# in which case these default settings will be overridden for the
# virtual host being defined.
# ServerAdmin: Your address, where problems with the server should be
# e-mailed.  This address appears on some server-generated pages, such
# as error documents.  e.g. admin@your-domain.com
ServerAdmin you@example.com
# ServerName gives the name and port that the server uses to identify itself.
# This can often be determined automatically, but we recommend you specify
# it explicitly to prevent problems during startup.
# If your host doesn't have a registered DNS name, enter its IP address here.
#ServerName www.example.com:8080
# Deny access to the entirety of your server's filesystem. You must
# explicitly permit access to web content directories in other
# <Directory> blocks below.
<Directory />
    AllowOverride none
    Require all denied
</Directory>
# Note that from this point forward you must specifically allow
# particular features to be enabled - so if something's not working as
# you might expect, make sure that you have specifically enabled it
# below.
# DocumentRoot: The directory out of which you will serve your
# documents. By default, all requests are taken from this directory, but
# symbolic links and aliases may be used to point to other locations.
DocumentRoot "/usr/local/homebrew/var/www"
<Directory "/usr/local/homebrew/var/www">
    # Possible values for the Options directive are "None", "All",
    # or any combination of:
    #   Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
    # Note that "MultiViews" must be named *explicitly* --- "Options All"
    # doesn't give it to you.
    # The Options directive is both complicated and important.  Please see
    # http://httpd.apache.org/docs/2.4/mod/core.html#options
    # for more information.
    # AllowOverride controls what directives may be placed in .htaccess files.
    # It can be "All", "None", or any combination of the keywords:
    #   AllowOverride FileInfo AuthConfig Limit
    AllowOverride None
    # Controls who can get stuff from this server.
    Require all granted
</Directory>
# DirectoryIndex: sets the file that Apache will serve if a directory
# is requested.
<IfModule dir_module>
    DirectoryIndex index.html
</IfModule>
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<Files ".ht*">
    Require all denied
</Files>
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here.  If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog "/usr/local/homebrew/var/log/httpd/error_log"
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
<IfModule log_config_module>
    # The following directives define some format nicknames for use with
    # a CustomLog directive (see below).
    LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
    LogFormat "%h %l %u %t \"%r\" %>s %b" common
    <IfModule logio_module>
      # You need to enable mod_logio.c to use %I and %O
      LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
    </IfModule>
    # The location and format of the access logfile (Common Logfile Format).
    # If you do not define any access logfiles within a <VirtualHost>
    # container, they will be logged here.  Contrariwise, if you *do*
    # define per-<VirtualHost> access logfiles, transactions will be
    # logged therein and *not* in this file.
    CustomLog "/usr/local/homebrew/var/log/httpd/access_log" common
    # If you prefer a logfile with access, agent, and referer information
    # (Combined Logfile Format) you can use the following directive.
    #CustomLog "/usr/local/homebrew/var/log/httpd/access_log" combined
</IfModule>
<IfModule alias_module>
    # Redirect: Allows you to tell clients about documents that used to
    # exist in your server's namespace, but do not anymore. The client
    # will make a new request for the document at its new location.
    # Example:
    # Redirect permanent /foo http://www.example.com/bar
    # Alias: Maps web paths into filesystem paths and is used to
    # access content that does not live under the DocumentRoot.
    # Example:
    # Alias /webpath /full/filesystem/path
    # If you include a trailing / on /webpath then the server will
    # require it to be present in the URL.  You will also likely
    # need to provide a <Directory> section to allow access to
    # the filesystem path.
    # ScriptAlias: This controls which directories contain server scripts.
    # ScriptAliases are essentially the same as Aliases, except that
    # documents in the target directory are treated as applications and
    # run by the server when requested rather than as documents sent to the
    # client.  The same rules about trailing "/" apply to ScriptAlias
    # directives as to Alias.
    ScriptAlias /cgi-bin/ "/usr/local/homebrew/var/www/cgi-bin/"
</IfModule>
<IfModule cgid_module>
    # ScriptSock: On threaded servers, designate the path to the UNIX
    # socket used to communicate with the CGI daemon of mod_cgid.
    #Scriptsock cgisock
</IfModule>
# "/usr/local/homebrew/var/www/cgi-bin" should be changed to whatever your ScriptAliased
# CGI directory exists, if you have that configured.
<Directory "/usr/local/homebrew/var/www/cgi-bin">
    AllowOverride None
    Options None
    Require all granted
</Directory>
<IfModule headers_module>
    # Avoid passing HTTP_PROXY environment to CGI's on this or any proxied
    # backend servers which have lingering "httpoxy" defects.
    # 'Proxy' request header is undefined by the IETF, not listed by IANA
    RequestHeader unset Proxy early
</IfModule>
<IfModule mime_module>
    # TypesConfig points to the file containing the list of mappings from
    # filename extension to MIME-type.
    TypesConfig /usr/local/homebrew/etc/httpd/mime.types
    # AddType allows you to add to or override the MIME configuration
    # file specified in TypesConfig for specific file types.
    #AddType application/x-gzip .tgz
    # AddEncoding allows you to have certain browsers uncompress
    # information on the fly. Note: Not all browsers support this.
    #AddEncoding x-compress .Z
    #AddEncoding x-gzip .gz .tgz
    # If the AddEncoding directives above are commented-out, then you
    # probably should define those extensions to indicate media types:
    AddType application/x-compress .Z
    AddType application/x-gzip .gz .tgz
    # AddHandler allows you to map certain file extensions to "handlers":
    # actions unrelated to filetype. These can be either built into the server
    # or added with the Action directive (see below)
    # To use CGI scripts outside of ScriptAliased directories:
    # (You will also need to add "ExecCGI" to the "Options" directive.)
    #AddHandler cgi-script .cgi
    # For type maps (negotiated resources):
    #AddHandler type-map var
    # Filters allow you to process content before it is sent to the client.
    # To parse .shtml files for server-side includes (SSI):
    # (You will also need to add "Includes" to the "Options" directive.)
    #AddType text/html .shtml
    #AddOutputFilter INCLUDES .shtml
</IfModule>
# The mod_mime_magic module allows the server to use various hints from the
# contents of the file itself to determine its type.  The MIMEMagicFile
# directive tells the module where the hint definitions are located.
#MIMEMagicFile /usr/local/homebrew/etc/httpd/magic
# Customizable error responses come in three flavors:
# 1) plain text 2) local redirects 3) external redirects
# Some examples:
#ErrorDocument 500 "The server made a boo boo."
#ErrorDocument 404 /missing.html
#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
#ErrorDocument 402 http://www.example.com/subscription_info.html
# MaxRanges: Maximum number of Ranges in a request before
# returning the entire resource, or one of the special
# values 'default', 'none' or 'unlimited'.
# Default setting is to accept 200 Ranges.
#MaxRanges unlimited
# EnableMMAP and EnableSendfile: On systems that support it,
# memory-mapping or the sendfile syscall may be used to deliver
# files.  This usually improves server performance, but must
# be turned off when serving from networked-mounted
# filesystems or if support for these functions is otherwise
# broken on your system.
# Defaults: EnableMMAP On, EnableSendfile Off
#EnableMMAP off
#EnableSendfile on
# Supplemental configuration
# The configuration files in the /usr/local/homebrew/etc/httpd/extra/ directory can be
# included to add extra features or to modify the default configuration of
# the server, or you may simply copy their contents here and change as
# necessary.
# Server-pool management (MPM specific)
#Include /usr/local/homebrew/etc/httpd/extra/httpd-mpm.conf
# Multi-language error messages
#Include /usr/local/homebrew/etc/httpd/extra/httpd-multilang-errordoc.conf
# Fancy directory listings
#Include /usr/local/homebrew/etc/httpd/extra/httpd-autoindex.conf
# Language settings
#Include /usr/local/homebrew/etc/httpd/extra/httpd-languages.conf
# User home directories
#Include /usr/local/homebrew/etc/httpd/extra/httpd-userdir.conf
# Real-time info on requests and configuration
#Include /usr/local/homebrew/etc/httpd/extra/httpd-info.conf
# Virtual hosts
#Include /usr/local/homebrew/etc/httpd/extra/httpd-vhosts.conf
# Local access to the Apache HTTP Server Manual
#Include /usr/local/homebrew/etc/httpd/extra/httpd-manual.conf
# Distributed authoring and versioning (WebDAV)
#Include /usr/local/homebrew/etc/httpd/extra/httpd-dav.conf
# Various default settings
#Include /usr/local/homebrew/etc/httpd/extra/httpd-default.conf
# Configure mod_proxy_html to understand HTML4/XHTML1
<IfModule proxy_html_module>
Include /usr/local/homebrew/etc/httpd/extra/proxy-html.conf
</IfModule>
# Secure (SSL/TLS) connections
#Include /usr/local/homebrew/etc/httpd/extra/httpd-ssl.conf
# Note: The following must must be present to support
#       starting without SSL on platforms with no /dev/random equivalent
#       but a statically compiled-in mod_ssl.
<IfModule ssl_module>
SSLRandomSeed startup builtin
SSLRandomSeed connect builtin
</IfModule>
/var/log/letsencrypt/letsencrypt.log
2024-02-10 19:45:52,864:DEBUG:certbot._internal.main:certbot version: 2.9.0
2024-02-10 19:45:52,865:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/local/homebrew/bin/certbot
2024-02-10 19:45:52,865:DEBUG:certbot._internal.main:Arguments: ['--apache', '-v']
2024-02-10 19:45:52,865:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#nginx,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2024-02-10 19:45:52,884:DEBUG:certbot._internal.log:Root logging level set at 20
2024-02-10 19:45:52,885:DEBUG:certbot._internal.plugins.selection:Requested authenticator apache and installer apache
2024-02-10 19:45:53,110:DEBUG:certbot_apache._internal.configurator:Apache version is 2.4.58
2024-02-10 19:45:53,286:WARNING:certbot_apache._internal.configurator:ssl_module is statically linked but --apache-bin is missing; not disabling session tickets.
2024-02-10 19:45:53,287:DEBUG:certbot._internal.plugins.selection:Single candidate plugin: * apache
Description: Apache Web Server plugin
Interfaces: Authenticator, Installer, Plugin
Entry point: EntryPoint(name='apache', value='certbot_apache._internal.entrypoint:ENTRYPOINT', group='certbot.plugins')
Initialized: <certbot_apache._internal.override_darwin.DarwinConfigurator object at 0x10415f830>
Prep: True
2024-02-10 19:45:53,288:DEBUG:certbot._internal.plugins.selection:Single candidate plugin: * apache
Prep: True
2024-02-10 19:45:53,288:DEBUG:certbot._internal.plugins.selection:Selected authenticator <certbot_apache._internal.override_darwin.DarwinConfigurator object at 0x10415f830> and installer <certbot_apache._internal.override_darwin.DarwinConfigurator object at 0x10415f830>
2024-02-10 19:45:53,288:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator apache, Installer apache
2024-02-10 19:45:53,339:DEBUG:certbot._internal.main:Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-v02.api.letsencrypt.org/acme/acct/1562413537', new_authzr_uri=None, terms_of_service=None), 396b4c32e22f0ff10c186fffd61a28ac, Meta(creation_dt=datetime.datetime(2024, 2, 9, 20, 4, 4, tzinfo=<UTC>), creation_host='ec2-52-26-148-183.us-west-2.compute.amazonaws.com', register_to_eff=None))>
2024-02-10 19:45:53,349:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2024-02-10 19:45:53,355:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2024-02-10 19:45:53,536:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 752
2024-02-10 19:45:53,537:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 11 Feb 2024 00:45:53 GMT
Content-Length: 752
X-Frame-Options: DENY
  "CROCHvwPmzs": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
  "meta": {
    "caaIdentities": [
      "letsencrypt.org"
    "termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.3-September-21-2022.pdf",
  "renewalInfo": "https://acme-v02.api.letsencrypt.org/draft-ietf-acme-ari-02/renewalInfo/",
2024-02-10 19:45:56,560:DEBUG:certbot._internal.display.obj:Notifying user: Requesting a certificate for test123domain.xyz
2024-02-10 19:45:56,566:DEBUG:acme.client:Requesting fresh nonce
2024-02-10 19:45:56,566:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2024-02-10 19:45:56,632:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2024-02-10 19:45:56,633:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 11 Feb 2024 00:45:56 GMT
Replay-Nonce: 6HUcA-o5oIQq2BLHfsD78DSc03ln-CZwr1ZIB0UvtxpmS6EnjQ0
2024-02-10 19:45:56,634:DEBUG:acme.client:Storing nonce: 6HUcA-o5oIQq2BLHfsD78DSc03ln-CZwr1ZIB0UvtxpmS6EnjQ0
2024-02-10 19:45:56,634:DEBUG:acme.client:JWS payload:
b'{\n  "identifiers": [\n    {\n      "type": "dns",\n      "value": "test123domain.xyz"\n    }\n  ]\n}'
2024-02-10 19:45:56,639:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTU2MjQxMzUzNyIsICJub25jZSI6ICI2SFVjQS1vNW9JUXEyQkxIZnNENzhEU2MwM2xuLUNad3IxWklCMFV2dHhwbVM2RW5qUTAiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL25ldy1vcmRlciJ9",
  "signature": "XvnWOeHlOQ9nIlKhDX32Bi7h1bxXOGsraVMQa6uWR-w19tym2YixlnzAYQxmu4OkCyJsgl7pvcOmmAFRWbEzHhi8voHOWhGd0hgGrr66M4ksPOykqkz7W5tq8bCl8PosbTonBKTZqeB6udrRByI-zs4m1rXQWGqlq_xaSQQRVKZOFjCsPzOmYcan_EBc_HztV5lnaH-UAOgwfAtrR4klBU4MovnquEwBz_wolpSj1rlkEswrEcMkIOGa26YS46-L1UouQ-jCXRCSM2nQOM9Kc8U4fklOcAH42JGSFUz_0UPVTuHgN5X9RGVZ42xnZkFSHEYUnrj9ckjOy5PIhLyZ4g",
  "payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogInRlc3QxMjNkb21haW4ueHl6IgogICAgfQogIF0KfQ"
2024-02-10 19:45:56,840:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 343
2024-02-10 19:45:56,841:DEBUG:acme.client:Received response:
HTTP 201
Server: nginx
Content-Length: 343
Boulder-Requester: 1562413537
Location: https://acme-v02.api.letsencrypt.org/acme/order/1562413537/243494024607
Replay-Nonce: 6HUcA-o5xDL1zr2wyxtkNh7y_UqQ8jPxNTR_lkzPC3mhJUALp4k
  "status": "pending",
  "expires": "2024-02-18T00:45:56Z",
  "identifiers": [
      "type": "dns",
  "authorizations": [
    "https://acme-v02.api.letsencrypt.org/acme/authz-v3/313871287387"
  "finalize": "https://acme-v02.api.letsencrypt.org/acme/finalize/1562413537/243494024607"
2024-02-10 19:45:56,841:DEBUG:acme.client:Storing nonce: 6HUcA-o5xDL1zr2wyxtkNh7y_UqQ8jPxNTR_lkzPC3mhJUALp4k
2024-02-10 19:45:56,842:DEBUG:acme.client:JWS payload:
b''
2024-02-10 19:45:56,844:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/313871287387:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTU2MjQxMzUzNyIsICJub25jZSI6ICI2SFVjQS1vNXhETDF6cjJ3eXh0a05oN3lfVXFROGpQeE5UUl9sa3pQQzNtaEpVQUxwNGsiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LXYzLzMxMzg3MTI4NzM4NyJ9",
  "signature": "n3e8SsWEG9iMIl1LoFOYdqI-Ky4blm0A8A3Keiub-YYOWUObOj73goBovooJ0hdYc5k4So3Cro2Tz_qJJZW4z_gPx3CqWYpimRFX_MMRPycK38XoT30XNgAoAUPsiAwXPIul_ijiXlkrazcShK_FwJC44cJ4C2-2_UwH7ObbX6b5KSBgh5UhEBzOg8oZ90i8nBTI30n7ZenMuXQmS0rCMUPFbK0rZCnMrpmP5Sg7Lgz_pAfGwzJm44QmKsI-a8mp1Wi51L07Z6M3Nb8JW-tDcvon3mCIyAhXYMIcnzls_H9csY33pT_4jlcl7bsD06vWbPIRmYVZzzvKMNPrfqYzpQ",
  "payload": ""
2024-02-10 19:45:56,909:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/313871287387 HTTP/1.1" 200 801
2024-02-10 19:45:56,911:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 801
Replay-Nonce: 6HUcA-o5H1NOL4TsXxibw-I90ef5-Q_WMIRVTr7sVdEPs3YBbpk
  "identifier": {
    "type": "dns",
  "challenges": [
      "type": "http-01",
      "url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/313871287387/Vnq-eA",
      "token": "A7HAIjl23t7khlUDfm27Cp-q3oUfF_9Mup95LyH-E38"
      "type": "dns-01",
      "url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/313871287387/K7NMxg",
      "type": "tls-alpn-01",
      "url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/313871287387/jKLWPA",
2024-02-10 19:45:56,911:DEBUG:acme.client:Storing nonce: 6HUcA-o5H1NOL4TsXxibw-I90ef5-Q_WMIRVTr7sVdEPs3YBbpk
2024-02-10 19:45:56,912:INFO:certbot._internal.auth_handler:Performing the following challenges:
2024-02-10 19:45:56,912:INFO:certbot._internal.auth_handler:http-01 challenge for test123domain.xyz
2024-02-10 19:45:56,919:DEBUG:certbot_apache._internal.http_01:Adding a temporary challenge validation Include for name: test123domain.xyz in: /usr/local/homebrew/etc/httpd/httpd.conf
2024-02-10 19:45:56,920:DEBUG:certbot_apache._internal.http_01:writing a pre config file with text:
         RewriteEngine on
        RewriteRule ^/\.well-known/acme-challenge/([A-Za-z0-9-_=]+)$ /var/lib/letsencrypt/http_challenges/$1 [END]
2024-02-10 19:45:56,920:DEBUG:certbot_apache._internal.http_01:writing a post config file with text:
         <Directory /var/lib/letsencrypt/http_challenges>
            Require all granted
        </Directory>
        <Location /.well-known/acme-challenge>
            Require all granted
        </Location>
2024-02-10 19:45:56,953:DEBUG:certbot.reverter:Creating backup of /usr/local/homebrew/etc/httpd/httpd.conf
2024-02-10 19:46:00,079:DEBUG:acme.client:JWS payload:
b'{}'
2024-02-10 19:46:00,083:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/313871287387/Vnq-eA:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTU2MjQxMzUzNyIsICJub25jZSI6ICI2SFVjQS1vNUgxTk9MNFRzWHhpYnctSTkwZWY1LVFfV01JUlZUcjdzVmRFUHMzWUJicGsiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2NoYWxsLXYzLzMxMzg3MTI4NzM4Ny9WbnEtZUEifQ",
  "signature": "gGYvTUM1dOnxbCyNkbhqBdC0kukAgM0-xLdjMozRWIJlAVavkPyZ2SJWPTB9P3pxtlOiSrJ8vghddyNZ8pFaLtwK9e_bctGGc1Lf-Q_HgxElXpXtU-AvL76EF0Jk4pjZnYoFrJxPqvVc7pKmGARzfRVbW5074irNgCp_MpyFuYWC8czSsDt3sV8JOQJk_25P75_xed4XQ9Ecd93F3V1rNpMgWtYsYC-GTqxKs_3ZSGlaN7-tywsIS3iZjqLJUC5k668g6ElKSauJhPYMjK5AYk6aUamPpfZ801Cp0VQzhc93geuJdS1W0ikMAUmo9jp1QI37adYiAF0_JaRUgv7BZg",
  "payload": "e30"
2024-02-10 19:46:00,192:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/chall-v3/313871287387/Vnq-eA HTTP/1.1" 200 187
2024-02-10 19:46:00,193:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 11 Feb 2024 00:46:00 GMT
Content-Length: 187
Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index", <https://acme-v02.api.letsencrypt.org/acme/authz-v3/313871287387>;rel="up"
Location: https://acme-v02.api.letsencrypt.org/acme/chall-v3/313871287387/Vnq-eA
Replay-Nonce: 6HUcA-o5pNyQozll_ldXL3BIeZKuYbcZyE_dEVWSn2p4zPSp1N4
  "type": "http-01",
2024-02-10 19:46:00,193:DEBUG:acme.client:Storing nonce: 6HUcA-o5pNyQozll_ldXL3BIeZKuYbcZyE_dEVWSn2p4zPSp1N4
2024-02-10 19:46:00,194:INFO:certbot._internal.auth_handler:Waiting for verification...
2024-02-10 19:46:01,199:DEBUG:acme.client:JWS payload:
b''
2024-02-10 19:46:01,204:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/313871287387:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTU2MjQxMzUzNyIsICJub25jZSI6ICI2SFVjQS1vNXBOeVFvemxsX2xkWEwzQkllWkt1WWJjWnlFX2RFVldTbjJwNHpQU3AxTjQiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LXYzLzMxMzg3MTI4NzM4NyJ9",
  "signature": "yj8AW0Qu-kChH-OzsPyhoatDFXGWknhy4hGlIOQdgRr-3NOZelyprA5dRXuS1ocGkY9Ytonhgii6_yINi9x_2xtjEDWIN19usq8wIsDItRgj9VjetH6-T5WXgwlRQ2FWkVxf0WZ5DkhnNIeDpb4cZAsXBBtBb7uBO9HK9wBNXL_Sj3udJHFHKhxk-hifiwQlBH5eQInNew9xJI7f61aa5rF_JaAlcizwD75QkND104SRoh967UDPxchsV0TYl4wmiOKT89cjHyDnHGv2zXE8UJ9ylRlNBUAsk3fuRtdLNm2whMgIv1nQntUNs0zqCVICE1fthybtRNblgPhSiq5Vvw",
  "payload": ""
2024-02-10 19:46:01,268:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/313871287387 HTTP/1.1" 200 801
2024-02-10 19:46:01,269:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 11 Feb 2024 00:46:01 GMT
Content-Length: 801
Replay-Nonce: 6HUcA-o5PcQwfyJtl3DNVavSkNCPfIQQAcNSyQC__nAkgO8XuAY
  "identifier": {
    "type": "dns",
  "challenges": [
      "type": "http-01",
      "type": "dns-01",
2024-02-10 19:46:01,270:DEBUG:acme.client:Storing nonce: 6HUcA-o5PcQwfyJtl3DNVavSkNCPfIQQAcNSyQC__nAkgO8XuAY
2024-02-10 19:46:04,275:DEBUG:acme.client:JWS payload:
b''
2024-02-10 19:46:04,280:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/313871287387:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTU2MjQxMzUzNyIsICJub25jZSI6ICI2SFVjQS1vNVBjUXdmeUp0bDNETlZhdlNrTkNQZklRUUFjTlN5UUNfX25Ba2dPOFh1QVkiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LXYzLzMxMzg3MTI4NzM4NyJ9",
  "signature": "Oujs3xLtIogV4YP-C_r86HZBQYW4qGPdzX5FQ2dGWFUdY4fV9DYGLbo0XLa6cm77EdNmvnwh_rp_6lGInFT6ptk5TUdY6dQ2oyW21ZaJzWvgDMg3uZihojd4WmehtDTNAYzdcGsA4JFMGGDgVGwV46y-qPE5TiBaujoTyeQ7BEe6zFX1mJS1MefQjFikwImw14wMpmRJu8xJmP2K5Mr4v7pJwLGGXIyBTzBbITxZKU4kDb_XazBJrPdOyq904jzie0OPEHBmneXlF_K-Yqq8Zzpte7HKxHXuOuIB9WXupluGUs5Mqj9kQEP7ikrgLZF6bDMQ8A_6_3e7Cz1zv6zq7A",
  "payload": ""
2024-02-10 19:46:04,395:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/313871287387 HTTP/1.1" 200 801
2024-02-10 19:46:04,396:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 11 Feb 2024 00:46:04 GMT
Content-Length: 801
Replay-Nonce: 6HUcA-o51KtvRN-VtTAfRAE5ce5xeCPhDfNwJAgxzqsXMuN11G8
  "identifier": {
    "type": "dns",
  "challenges": [
      "type": "http-01",
      "type": "dns-01",
2024-02-10 19:46:04,396:DEBUG:acme.client:Storing nonce: 6HUcA-o51KtvRN-VtTAfRAE5ce5xeCPhDfNwJAgxzqsXMuN11G8
2024-02-10 19:46:07,404:DEBUG:acme.client:JWS payload:
b''
2024-02-10 19:46:07,407:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/313871287387:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTU2MjQxMzUzNyIsICJub25jZSI6ICI2SFVjQS1vNTFLdHZSTi1WdFRBZlJBRTVjZTV4ZUNQaERmTndKQWd4enFzWE11TjExRzgiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LXYzLzMxMzg3MTI4NzM4NyJ9",
  "signature": "qrvBa9RMFHNZciYN_OlcI57OFhnwlUczsRTr1lmEzfTdlRlDqMuyPnjeowahFKEzQKXdDjHeAB-FFTj7yBHkRwDMDvVMgFy0xJy0uZxBPQRSivsn1zqNztXkstV3YHj6RL4Z5f6qLVIlgzEDB6Dk9MS2rewZFtAzAURwrCW1PillsLae5H0nPreWjDSr9mGOx2JTBP7r6v0YrjfN1LU4x1vwYif39LMdrnjrW8XpewXHUswwm9BS2lOxMGcYWN4HSl8J746RPjxofgKey_1qZbwiOHt8BhHudprWWzPoAmsPG8YoreFEJ1JoSJnD6-t3yugLj6xfu08osL8jou1IVg",
  "payload": ""
2024-02-10 19:46:07,474:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/313871287387 HTTP/1.1" 200 801
2024-02-10 19:46:07,475:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 11 Feb 2024 00:46:07 GMT
Content-Length: 801
Replay-Nonce: HWHXB1ulavvpSHk3lwPjJtAGxJ39P0vhmPRmeu3WtxZc0Rc3S8g
  "identifier": {
    "type": "dns",
  "challenges": [
      "type": "http-01",
      "type": "dns-01",
2024-02-10 19:46:07,475:DEBUG:acme.client:Storing nonce: HWHXB1ulavvpSHk3lwPjJtAGxJ39P0vhmPRmeu3WtxZc0Rc3S8g
2024-02-10 19:46:10,479:DEBUG:acme.client:JWS payload:
b''
2024-02-10 19:46:10,482:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/313871287387:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTU2MjQxMzUzNyIsICJub25jZSI6ICJIV0hYQjF1bGF2dnBTSGszbHdQakp0QUd4SjM5UDB2aG1QUm1ldTNXdHhaYzBSYzNTOGciLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LXYzLzMxMzg3MTI4NzM4NyJ9",
  "signature": "LvSt4Og_SdHmV9Z2TGzLUlwztyOXuhX7i4rOQu2T_rPSHpw0vM6jVNbInYghUDTwGm0cihs_mIEVwoISwbHEVTUrIfaQXULCuaBdQbZERf2tUAYqmUcMnXUGbQUVcUv_8Dg0jbBLl1Br4wzyvdgsB7iIRdCdIZjYJWVHSDSP_uABJEcbrRIzrzpyRCM2ivZFs1TCOdDF-Qf9BEa6ILmj5YROXF9HS95JkGPsxzdX4cgq7czawl6MMniLKA395yBvRJ1LuMRHdlMBnjadMxKpxtr1IZ2qPlex00vLJpW-OVkfX4S7k7L6sQY14t7GYo4G6QSpbZq3RISw8rAulLhpWg",
  "payload": ""
2024-02-10 19:46:10,573:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/313871287387 HTTP/1.1" 200 801
2024-02-10 19:46:10,575:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 11 Feb 2024 00:46:10 GMT
Content-Length: 801
Replay-Nonce: HWHXB1ul-gIcAulmsoiyD-VVtJYkDLb-7PCRFmeL0GDvQ-7v1pY
  "identifier": {
    "type": "dns",
  "challenges": [
      "type": "http-01",
      "type": "dns-01",
2024-02-10 19:46:10,575:DEBUG:acme.client:Storing nonce: HWHXB1ul-gIcAulmsoiyD-VVtJYkDLb-7PCRFmeL0GDvQ-7v1pY
2024-02-10 19:46:13,581:DEBUG:acme.client:JWS payload:
b''
2024-02-10 19:46:13,583:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/313871287387:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTU2MjQxMzUzNyIsICJub25jZSI6ICJIV0hYQjF1bC1nSWNBdWxtc29peUQtVlZ0SllrRExiLTdQQ1JGbWVMMEdEdlEtN3YxcFkiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LXYzLzMxMzg3MTI4NzM4NyJ9",
  "signature": "g_e7BWGBw4PXJdRmOYKLZkHLkakGjgNLs6r5sjXLGNwnZ1JYLtyDsq5_v7FhxKk9NeFWIo8SKn6RA4W8RheE5KNJCfsX6_8C90VsSsp-jUq2cIAbuz9Fwilx4StuFlBE7c0ADYcDtg97uXwFckJPJknOG1EgKpCPdFhBRhdXIjafTgzhquEu_JjbwoCMmli2yBfBFDtRlc7kwdqEqBpMcLmnBL6ROap-l5S5jr2RH_ZD-sUWyOKP_J_bfG_49e_nQFuH8tjcoMjXcoQff9U0MqpaM4SK20SdRzKfAL-MvSI-aTTqw9OYKDod4GQNly_SJKKfEvJ0x1CAoxLINiUM7Q",
  "payload": ""
2024-02-10 19:46:13,650:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/313871287387 HTTP/1.1" 200 1178
2024-02-10 19:46:13,652:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 11 Feb 2024 00:46:13 GMT
Content-Length: 1178
Replay-Nonce: 6HUcA-o521McGA13sobi-RJYxwzj1XjvYsu-wH5TVhxOX8hGecM
  "identifier": {
    "type": "dns",
  "status": "invalid",
  "challenges": [
      "type": "http-01",
      "error": {
        "type": "urn:ietf:params:acme:error:connection",
        "detail": "104.171.54.23: Fetching http://test123domain.xyz/.well-known/acme-challenge/A7HAIjl23t7khlUDfm27Cp-q3oUfF_9Mup95LyH-E38: Timeout during connect (likely firewall problem)",
        "status": 400
      "token": "A7HAIjl23t7khlUDfm27Cp-q3oUfF_9Mup95LyH-E38",
      "validationRecord": [
          "url": "http://test123domain.xyz/.well-known/acme-challenge/A7HAIjl23t7khlUDfm27Cp-q3oUfF_9Mup95LyH-E38",
          "hostname": "test123domain.xyz",
          "port": "80",
          "addressesResolved": [
            "104.171.54.23"
          "addressUsed": "104.171.54.23",
          "resolverAddrs": [
            "A:10.1.12.81:20241",
            "AAAA:10.1.12.83:21802"
      "validated": "2024-02-11T00:46:00Z"
2024-02-10 19:46:13,654:DEBUG:acme.client:Storing nonce: 6HUcA-o521McGA13sobi-RJYxwzj1XjvYsu-wH5TVhxOX8hGecM
2024-02-10 19:46:13,655:INFO:certbot._internal.auth_handler:Challenge failed for domain test123domain.xyz
2024-02-10 19:46:13,655:INFO:certbot._internal.auth_handler:http-01 challenge for test123domain.xyz
2024-02-10 19:46:13,655:DEBUG:certbot._internal.display.obj:Notifying user:
  Type:   connection
2024-02-10 19:46:13,658:DEBUG:certbot._internal.error_handler:Encountered exception:
  File "/usr/local/homebrew/Cellar/certbot/2.9.0/libexec/lib/python3.12/site-packages/certbot/_internal/auth_handler.py", line 108, in handle_authorizations
    self._poll_authorizations(authzrs, max_retries, max_time_mins, best_effort)
  File "/usr/local/homebrew/Cellar/certbot/2.9.0/libexec/lib/python3.12/site-packages/certbot/_internal/auth_handler.py", line 212, in _poll_authorizations
2024-02-10 19:46:13,658:DEBUG:certbot._internal.error_handler:Calling registered functions
2024-02-10 19:46:13,658:INFO:certbot._internal.auth_handler:Cleaning up challenges
2024-02-10 19:46:13,829:DEBUG:certbot._internal.log:Exiting abnormally:
  File "/usr/local/homebrew/bin/certbot", line 8, in <module>
    sys.exit(main())
  File "/usr/local/homebrew/Cellar/certbot/2.9.0/libexec/lib/python3.12/site-packages/certbot/main.py", line 19, in main
  File "/usr/local/homebrew/Cellar/certbot/2.9.0/libexec/lib/python3.12/site-packages/certbot/_internal/main.py", line 1894, in main
  File "/usr/local/homebrew/Cellar/certbot/2.9.0/libexec/lib/python3.12/site-packages/certbot/_internal/main.py", line 1600, in certonly
    lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
  File "/usr/local/homebrew/Cellar/certbot/2.9.0/libexec/lib/python3.12/site-packages/certbot/_internal/main.py", line 143, in _get_and_save_cert
  File "/usr/local/homebrew/Cellar/certbot/2.9.0/libexec/lib/python3.12/site-packages/certbot/_internal/client.py", line 517, in obtain_and_enroll_certificate
  File "/usr/local/homebrew/Cellar/certbot/2.9.0/libexec/lib/python3.12/site-packages/certbot/_internal/client.py", line 428, in obtain_certificate
  File "/usr/local/homebrew/Cellar/certbot/2.9.0/libexec/lib/python3.12/site-packages/certbot/_internal/client.py", line 496, in _get_order_and_authorizations
2024-02-10 19:46:13,831:ERROR:certbot._internal.log:Some challenges have failed.
I have one question:
Do you own/control the domain "test123domain.xyz"?
And one observation: LE can't reach that site via HTTP; As shown in the error message below.
You need to have port 80 open for the HTTP Challenge done by the --apache plugin. You have port 443 open so you just need to do something similar for port 80
nmap -p80,443  test123domain.xyz
Nmap scan report for test123domain.xyz (104.171.54.23)
PORT    STATE    SERVICE
80/tcp  filtered http
443/tcp open     https
Your system is not able to connect on TCP port 80 (http) but does connect over TCP port 443 (https).
Your IP is a Cable internet company - are you 100% sure they support HTTP hosting? That's required for using HTTP validation to confirm your domain control with Let's Encrypt.
Alternatives are DNS validation or tls-alpn-01 (validation over port 443)
I think I know why ISP blocks port 80, thanks both for the diagnosis and suggestions.
