My domain is: www.limeira.sp.leg.br
It produced this output: ertbot failed to authenticate some domains (authenticator: apache). The Certificate Authority reported these problems:
Domain: www.limeira.sp.leg.br
Type: connection
Detail: 177.69.86.229: Fetching http://www.limeira.sp.leg.br/.well-known/acme-challenge/P7Ou25QU-j1vZ_mkuX8xZcJR6nm_o4VAcAlPhXrUNC4: Timeout during connect (likely firewall problem)
My web server is (include version): Apache/2.4.41 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu Server 20.4
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
My http server is behind a NAT, the NAT server redirects ports 80 and 443 to http server
administrador@vm-http:~$ sudo certbot --apache -v
[sudo] password for administrador:
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: limeira.sp.leg.br
2: concursoredacao.limeira.sp.leg.br
3: escolalegislativa.limeira.sp.leg.br
4: esic.limeira.sp.leg.br
5: gerenciador.limeira.sp.leg.br
6: ouvidoria.limeira.sp.leg.br
7: portaldatransparencia.limeira.sp.leg.br
8: teste.limeira.sp.leg.br
9: teste2.limeira.sp.leg.br
10: www.limeira.sp.leg.br
blank to select all options shown (Enter 'c' to cancel): 10
Requesting a certificate for www.limeira.sp.leg.br
http-01 challenge for www.limeira.sp.leg.br
Challenge failed for domain www.limeira.sp.leg.br
  Type:   connection
  Detail: 177.69.86.229: Fetching http://www.limeira.sp.leg.br/.well-known/acme-challenge/5hW9DzzPwHXWfs9pAYz5MmgvC9uVoZaxLxpqCF0wYXk: Timeout during connect (likely firewall problem)
Hello @andretoledo, welcome to the Let's Encrypt community. :slightly_smiling_face:
There is something between the Internet and www.limeira.sp.leg.br; likely a router / firewall, possibly even more than one.
:~$ nmap -Pn -p80,443 www.limeira.sp.leg.br
Starting Nmap 7.80 ( https://nmap.org ) at 2024-04-01 17:27 UTC
Nmap scan report for www.limeira.sp.leg.br (177.69.86.229)
Host is up.
rDNS record for 177.69.86.229: 177-069-086-229.static.ctbctelecom.com.br
PORT    STATE    SERVICE
80/tcp  filtered http
443/tcp filtered https
Nmap done: 1 IP address (1 host up) scanned in 4.90 seconds
I can connect to your domain with HTTP using a server in Brazil. But, I cannot connect from a US based server.
Let's Encrypt uses various points around the world to authenticate your domain.
You might have some kind of geographic limits in a firewall or even your ISP.
Once the firewall/timeout problem is overcome, you might want to change "10" to "1 10".
[if they both serve the exact same content]
Thank you very much, there really was a rule in our firewall that geo-blocked it.
