My domain is: k142.chickenkiller.com
It produced this output: Requesting a certificate for k142.chickenkiller.com
Domain: k142.chickenkiller.com
Type: connection
Detail: Fetching http://k142.chickenkiller.com/.well-known/acme-challenge/lemjuuZ6T10xVH98ksucCIYpA9o50zjFM9joVoQBPLg: Timeout during connect (likely firewall problem)
My web server is (include version): 192.168.128.133
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Apache
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.19.0
That error message means that Let's Encrypt can't connect to your website in order to validate that you own it. I can't connect to it from my system either. You need to ensure your website is globally accessible and working first before you can move to securing it by adding https.
Not sure why an IP was given as a response there...
Maybe "software" should be included in the form.
Likely unrelated, but interesting none-the-less.
It seems that MS SmartScreen doesn't like "Chicken Killer":
Hi, sorry for my bad English, i dont know what that question's meaning.:frowning:
Which web server do you use?
[Apache, nginx, Tomcat, LiteSpeed, etc.]
Hi there, I got a domain from https://freedns.afraid.org/subdomain and here is information of my domain:
I'm newbie in Let's Encrypt and don't know what to do
Hi, i'm using Apache.
Can you choose another free (public) domain?
Let's me try. Thanks for your help, I hope will be back with good news :<
Hi. I have got a free website with domain is k142.unaux.com.
And i have fail is image
Hope you or anyone help me :frowning: Im so dumb
Let's start with the output of:
sudo apachectl -t -D DUMP_VHOSTS
And why are these two IPs so different?:
Address:  185.27.134.216
Address:  14.255.76.114
Please show the output of:
curl -4 ifconfig.co
Hi rg305, thanks for your dedicated help. Thank you so much.
Here is output of sudo apachectl -t -D DUMP_VHOSTS:
And here is curl -4 ifconfig.co:
14.255.76.114
These two IPs are given when I get the domain name. k142.unaux was obtained by me on profreehost.com; k142.chickenkiller obtained from freedns.afraid.org.
It's have 3 hour since my last reply because i reinstall ubuntu, sorry
Let's have a look at the file:
/etc/apache2/sites-enabled/k142.unaux.com.conf
Here it is:
what should i do with k142.unaux website? eg install something?
and am i bothering you? i asked too much :frowning:
It is no bother.
The k142.unaux.com website should serve content found at that document root.
Let's try a couple of test files before continuing with certbot.
  1. echo root-test-file > /var/www/k142.unaux.com/Root-Test-File
  2. mkdir /var/www/k142.unaux.com/.well-known
    mkdir /var/www/k142.unaux.com/.well-known/acme-challenge
    echo c-t-file > /var/www/k142.unaux.com/.well-known/acme-challenge/C-T-File
Then we can check them with:
http://k142.unaux.com/Root-Test-File
http://k142.unaux.com/.well-known/acme-challenge/C-T-File
Looks like I'm wrong somewhere. it still error.
should i install nginx?
I do prefer nginx over apache.
But I'm not sure that will fix the problem; As I'm not yet certain where the problem is.
Did you make those files?
curl -4 ifconfig.co
Here it is: image
Btw, Im reading posts about Nginx and i see this:
i don't know have i done this?
