jmdok.chickenkiller.com
sudo sudo certbot --apache --staging -d jmdok.chickenkiller.com
Domain: jmdok.chickenkiller.com
Type: connection
Detail: Fetching
http://jmdok.chickenkiller.com/.well-known/acme-challenge/4dw40XKQMO28wdIp-_pc2yE1jlWJSqKIW5K7aYJwefs:
Apache
Ubuntu 18.04 LTS
N/A
I can login to a root shell on my machine (yes or no, or I don’t know): YES
No
certbot 0.31.0
I am running wireshark on my target machine and I see no requests coming in when running certbot. However, when I put http://jmdok.chickenkiller.com into a browser on another machine, I do see requests coming in and I get the apache front page. When I enter the URL that certbot is reporting, I got a Not Found response. It just seems like there is no connection coming from the certbot side.
I also tried LetsDebug.net and it too reported a failure to connect, and again I saw no messages in wireshark. The IP address in the log was correct, 24.115.193.85.
I got rate-limited running certbot, so I know my connections going out are working and certbot is trying to do it’s thing.
I am not sure where to look next. Do I need to open up any other ports on my firewall? Right now, I only have port 80 open.
Thanks for any advice.
Best Regards,
Joe
