HTTP-01 ...Timeout during connect (likely firewall problem)
My domain is: bread365.com
I ran this command: certbot -v
`[root@bread365 ~]# certbot -v
How would you like to authenticate and install certificates?
1: Apache Web Server plugin (apache)
2: Nginx Web Server plugin (nginx)
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: bread365.com
2: towniebread.com
Requesting a certificate for bread365.com
http-01 challenge for bread365.com
Challenge failed for domain bread365.com
Domain: bread365.com
Type: connection
Detail: 47.181.10.189: Fetching http://bread365.com/.well-known/acme-challenge/RKDwpepav4UnfRPWiiqj9qLNXQ0KOkbOEijjy3XL_rY: Timeout during connect (likely firewall problem)
[Beelink SER5 MAX Mini PC, AMD Ryzen 7 5800H(7nm, 8C/16T) up to 4.4GHz, Mini Computer 32GB DDR4 RAM 500GB NVME SSD,]
The operating system my web server runs on is (include version): Rocky Linux 9.3
I can login to a root shell on my machine (yes or no, or I don't know): YES
Sometime, command line or WEBMIN
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.6.0
My network is as follows:
I host my DNS on GoDaddy so I know DNS validation will NOT work.
47.181.10.189 - External IP
Goes through my router/firewall and gets addressed to my internal ip 192.168.2.222 My firewall/router will only route via IP it will not look at the name bread365.com only knows to route the ip
I can access my web server http://bread365.com via port 80 everything works on the virtual hosts. I have 2 set up but currently only setting up one for SSL. The other will be done when I move that to site to this new server at a later date.
The firewall on the Rocky Linux box has both port/service 80(http) and 443(https) set to ALLOW
in my HTTPD virtual host config
I have tried ANY for IP address or 192.168.2.222 - both fail
I've tried ANY for port or 80 - both fail.
I have the full letsencrypt.log file but nothing in there helps me figure out where its failing.
I do not see any requests coming into the access_log/ssl_access_log files for the web server from letsencrypt. I do see my requests coming in if I browse the site.
This isn't hard so I'm at a loss of why I can't figure it out - ha ha I've done it on few hosted sites without any problem along with others I have hosted.
Any help would be appreciated.
Welcome @AndyW
Sadly, connections from the public internet don't work. The place to start is double-check your router. The Let's Debug website is helpful to test comms on new servers.
Can you connect to that domain from outside your own network? Like with a mobile phone and wifi disabled to use your carrier's network?
Also, are you sure your ISP allows inbound connections on port 80 (and/or 443)? Some residential ISP's do not.
OMG, this is weird. I have a business line so the ip's work in both direction, and the IP above and below work through that same router. THANK YOU. This gives me new leads to go look at. I'll let you know what I find. Never thought of using web tools to test my site. Now I am. Thanks I'll update what foot I hit :wink:
Sorry this was totally me --- my web server was NOT accessible via the internet. You can close this issue
