galacticamc.xyz
# certbot --apache -d galacticamc.xyz -d www.galacticamc.xyz
Unable to read ssl_module file; not disabling session tickets.
Requesting a certificate for galacticamc.xyz and www.galacticamc.xyz
Domain: galacticamc.xyz
Type: connection
Detail: Fetching http://galacticamc.xyz/.well-known/acme-challenge/HRf5J7kaqTccFDRh5YiG0ZOHPsu-X4NVy6GqGcigJO0: Timeout during connect (likely firewall problem)
Domain: www.galacticamc.xyz
Type: connection
Detail: Fetching http://www.galacticamc.xyz/.well-known/acme-challenge/WYdrHz6HeLCYjsXIzgkItJEYm7PVNwO5OZUHnBk3_qE: Timeout during connect (likely firewall problem)
apache24
FreeBSD 12.2
n/a
no
certbot 1.18.0
