Port 80 open, no certificate ( Timeout during connect (likely firewall problem))
Hi all, I am new in security issues, so forgive me for the question! I have an apache server with the port 80 open, if I curl the url it returns the correct html content. The “certbot --apache” procedure ends in an error and I am not able to figure out the problem.
My domain is: bo.cnr.it
I ran this command: certbot --apache
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter ‘c’ to cancel): datavm.bo.cnr.it
http-01 challenge for datavm.bo.cnr.it
Enabled Apache rewrite module
Waiting for verification…
Failed authorization procedure. datavm.bo.cnr.it (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://datavm.bo.cnr.it/.well-known/acme-challenge/kyAFqHhXOuOHK9y62YZDDaz8PNHljAwYXFVWMyceE6A: Timeout during connect (likely firewall problem)
    Domain: datavm.bo.cnr.it
    Type: connection
    Detail: Fetching
My web server is (include version): datavm.bo.cnr.it
The operating system my web server runs on is (include version): Debian 9
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.28.0
Hi @AlessioGiberti
there is a check of your domain, created yesterday - https://check-your-website.server-daten.de/?q=datavm.bo.cnr.it (I've started the current check).
Same image: Only timeouts:
• http://datavm.bo.cnr.it/ 192.167.183.18 -14 10.023 T
Timeout - The operation has timed out
• https://datavm.bo.cnr.it/ 192.167.183.18 -14 10.033 T
• http://datavm.bo.cnr.it/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 192.167.183.18 -14 10.023 T
Visible Content:
• https://192.167.183.18/ 192.167.183.18 -14 10.026 T
Your ip answers via Ping.
Works yor webserver internal?
curl http://datavm.bo.cnr.it/
from that machine?
If yes, it's a firewall / routing problem.
Hi Juergen and thanks for your reply.
Yes, I can curl from that machine. So it is a firewall / routing problem. Below I paste the result of port scanning.
root@datavm:/home/alessio# lsof -i -P |grep LISTEN
sshd 523 root 3u IPv4 25654 0t0 TCP *:22 (LISTEN)
sshd 523 root 4u IPv6 25656 0t0 TCP *:22 (LISTEN)
exim4 1053 Debian-exim 3u IPv4 18494 0t0 TCP localhost:25 (LISTEN)
exim4 1053 Debian-exim 4u IPv6 18495 0t0 TCP localhost:25 (LISTEN)
grafana-s 1824 grafana 12u IPv6 21207 0t0 TCP *:3000 (LISTEN)
apache2 8905 root 4u IPv6 2774194 0t0 TCP *:80 (LISTEN)
apache2 9394 www-data 4u IPv6 2774194 0t0 TCP *:80 (LISTEN)
apache2 9395 www-data 4u IPv6 2774194 0t0 TCP *:80 (LISTEN)
apache2 9396 www-data 4u IPv6 2774194 0t0 TCP *:80 (LISTEN)
influxd 20549 influxdb 3u IPv4 2359533 0t0 TCP localhost:8088 (LISTEN)
influxd 20549 influxdb 44u IPv6 2367433 0t0 TCP *:8086 (LISTEN)
cupsd 29572 root 9u IPv6 2549111 0t0 TCP localhost:631 (LISTEN)
cupsd 29572 root 10u IPv4 2549112 0t0 TCP localhost:631 (LISTEN)
The firewall status:
root@datavm:/home/alessio# ufw status
Status: active
To Action From
443 ALLOW Anywhere
80 ALLOW Anywhere
22/tcp ALLOW Anywhere
80/tcp ALLOW Anywhere
443 (v6) ALLOW Anywhere (v6)
80 (v6) ALLOW Anywhere (v6)
22/tcp (v6) ALLOW Anywhere (v6)
80/tcp (v6) ALLOW Anywhere (v6)
See your Portchecks - https://check-your-website.server-daten.de/?q=datavm.bo.cnr.it#portchecks
datavm.bo.cnr.it
22
SSH
open
SSH-2.0-OpenSSH_7.4p1 Debian-10+deb9u7
answers, you must have something, that blocks.
