jayesh
October 19, 2019, 6:07am
1
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: ffcvapi.cruxvoice.in
requests.exceptions.ConnectTimeout: HTTPSConnectionPool(host=‘acme-v02.api.letsencrypt.org ’, port=443): Max retries exceeded with url: /directory (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7f3949f99390>, ‘Connection to acme-v02.api.letsencrypt.org timed out. (connect timeout=45)’))
Apache 2.4
The operating system my web server runs on is (include version): debian 9
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.28.0
Things which i have tried yet…
ran dig command and added /etc/hosts entry: 172.65.32.248 acme-v02.api.letsencrypt.org
tried few command suggested in other thread to check connectivity issues…
jayesh@web:~ curl -4 -X GET -I -m 10 https://acme-v02.api.letsencrypt.org/directory
curl: (28) Connection timed out after 10001 milliseconds
jayesh@web:~ curl -6 -X GET -I -m 10 https://acme-v02.api.letsencrypt.org/directory
curl: (7) Couldn’t connect to server
jayesh@web:~ head -c 35000 /dev/urandom | base64 | curl -d @- -i -X POST -m 10 -H 'Expect:' https://acme-v02.api.letsencrypt.org/acme/new-order
curl: (28) Connection timed out after 10000 milliseconds
jayesh@web:~ head -c 350 /dev/urandom | base64 | curl -d @- -i -X POST -m 10 -H ‘Expect:’ https://acme-v02.api.letsencrypt.org/acme/new-order
tried to change mtu setting with values 1300 and 1400. didn’t help.
Please help me to diagnose this issue.
Hi @jayesh
are you able to connect other domains?
curl https://www.google.com/
ping letsencrypt.org
traceroute letsencrypt.org
If your network is broken: Where is that server? Self hostet? Data center? If it’s a data center, ask your provider.
rg305
October 19, 2019, 6:20am
3
Remember to put things back.
Undo:
jayesh
October 19, 2019, 6:35am
4
Thanks for your reply and yes - I am able to connect other domains.
sharing outputs…
curl https://www.google.com/ => Recieved output, connected succesfully. Not posting output here because its too long.
ping letsencrypt.org =>
PING letsencrypt.org (134.209.106.40) 56(84) bytes of data.
64 bytes from 134.209.106.40 (134.209.106.40): icmp_seq=1 ttl=52 time=65.3 ms
64 bytes from 134.209.106.40 (134.209.106.40): icmp_seq=2 ttl=52 time=65.0 ms
64 bytes from 134.209.106.40 (134.209.106.40): icmp_seq=3 ttl=52 time=64.9 ms
64 bytes from 134.209.106.40 (134.209.106.40): icmp_seq=4 ttl=52 time=65.5 ms
^C
— letsencrypt.org ping statistics —
4 packets transmitted, 4 received, 0% packet loss, time 3003ms
rtt min/avg/max/mdev = 64.944/65.237/65.583/0.357 ms
traceroute to letsencrypt.org (206.189.89.118), 30 hops max, 60 byte packets
1 182.173.67.241 (182.173.67.241) 1.894 ms 1.317 ms 2.310 ms
2 192.168.0.166 (192.168.0.166) 0.983 ms 0.795 ms 0.969 ms
3 182.173.64.227 (182.173.64.227) 1.339 ms 1.037 ms 1.222 ms
4 115.113.163.25.static-pune.vsnl.net.in (115.113.163.25) 2.054 ms 3.048 ms 2.309 ms
5 172.31.155.174 (172.31.155.174) 2.161 ms 2.103 ms 2.315 ms
6 172.23.78.229 (172.23.78.229) 2.258 ms 1.946 ms 1.815 ms
7 172.17.169.202 (172.17.169.202) 29.072 ms 28.966 ms 29.007 ms
8 ix-ae-4-2.tcore1.cxr-chennai.as6453.net (180.87.36.9) 28.329 ms 27.301 ms 26.522 ms
9 if-ae-34-2.tcore1.svq-singapore.as6453.net (180.87.36.41) 66.767 ms 65.413 ms 65.493 ms
10 if-ae-7-2.thar1.svq-singapore.as6453.net (180.87.98.9) 65.095 ms 64.860 ms 65.002 ms
11 120.29.214.142 (120.29.214.142) 65.056 ms 65.052 ms 120.29.214.50 (120.29.214.50) 63.637 ms
12 * 138.197.245.9 (138.197.245.9) 65.671 ms 138.197.245.3 (138.197.245.3) 64.683 ms
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
Server is hosted in Data Center.
_az
October 19, 2019, 6:36am
5
You need a traceroute specifically to acme-v02.api.letsencrypt.org.
letsencrypt.org is entirely separate and not relevant to your original issue.
jayesh
October 19, 2019, 6:41am
6
Please find output..
traceroute acme-v02.api.letsencrypt.org
traceroute to acme-v02.api.letsencrypt.org (172.65.32.248), 30 hops max, 60 byte packets
1 182.173.67.241 (182.173.67.241) 1.328 ms 1.745 ms 2.247 ms
2 192.168.0.166 (192.168.0.166) 1.186 ms 1.017 ms 1.026 ms
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
_az
October 19, 2019, 6:42am
7
You need to talk to your host/NOC. Send them that last traceroute, it clearly conveys the problem.
jayesh
October 19, 2019, 6:49am
8
ok checking with them, Thanks a ton !!
will get back with results.
