My domain is: gamercraft.ga
I ran this command: certbot certonly -d gamercraft.ga
It produced this output: How would you like to authenticate with the ACME CA?
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 1
http-01 challenge for gamercraft.ga
Waiting for verification…
Failed authorization procedure. gamercraft.ga (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://gamercraft.ga/.well-known/acme-challenge/7CQj-JzVXi5oAit0m5w3BOx2P61q953__n9fF3WZUy4: Timeout during connect (likely firewall problem)
Domain: gamercraft.ga
Type: connection
Detail: Fetching
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
My web server is (include version): nginx version: nginx/1.14.0 (Ubuntu)
The operating system my web server runs on is (include version): ubuntu 18.04
My hosting provider, if applicable, is: self-host
I can log in to a root shell on my machine (yes or no, or I don’t know): yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
The first time I did it with another domain it worked after I changed domains and reset the server i get this error, if I try to connect to it I get connection refused
edit: troubleshooting steps: tried resetting my router, disabled the ufw
edit 2: ok update, only happens when Nginx is down. problem is neither nginx being disabled or enabled fixes this
