SSL enable automativally for my main domain, sub domain and mapping domain
Hello
I have a lot of website in Classic asp so i have to ennable SSL automatically i dont know hot to enable SSL automatically>
Case 1: I have use main and domain in this case i will use “Wild card” SSl but i gave option to my client to choose domain name in that case i have to poit out my subdomain to my client domain in that case how to auto enable my SSL? please give some advise
thanks in advance
That sounds like a DNS CNAME entry.
The client would need to obtain a cert that covers your name (the one that you pointed to their name).
[or both names, yours and theirs]
That is obtained as any other cert would be obtained - no extra complication.
To automate the renewals, they would need to find a client that can work in their system.
Hi @developer
that's not a question of your programming language.
That's a question of your environment.
Please answer the following questions:
Then start with some basics:
And select a client:
Sounds like you're looking for a way to force HTTP to HTTPS redirect, which is a server configuration issue as opposed to a Certificate issue. If you answer the questions posted by @JuergenAuer, we can better direct you how to accomplish that.
EDIT:
Re-reading & re-reading to make sure I understand what you're trying to accomplish.
If you're using a CNAME like @rg305 is stating, then the host you're pointing to needs to have an entry to handle the traffic for your subdomain. If you do not control the server it points to, then you have to get ahold of whoever controls the server to provide them with the cert.
However, if you set an A record for it to point to your server, you can set up the Certificate on the server & redirect it out that way. If you want to automate it, you'd have to write a script to pull data from your customer database & pass them into a configuration file.
