How to do SSL Auto Renewal
My domain is: api2.juvlon.com
My web server is (include version): ubuntu / centos
The operating system my web server runs on is (include version): ubuntu / centos
My hosting provider, if applicable, is: AWS
Depends on how you installed the certificate in the first place. Unfortunately, you didn’t mention the client you’ve used and you haven’t mentioned the command you’ve used to install it, so for now it’s impossible to answer the question.
Hello Sir
Actually i have a multiple domain which i had installed letsencrypt SSL domain and subdomain, its expire after every 90 days i want to set auto renewal for ssl, please suggest how to set auto renewal for domain on different server. i am using ubuntu and centos server also apache and nginx server.
How did you install the certificate originally?
Start on this page and tell us if you recognize anything familiar:
You didn't answer my questions: how did you install the certificates in the first place? What client did you use?
actully this installed by previous one administrator n now i am new here.
wait, @adityakamble
you do realize that your certificate was last renewed two days ago and it’s working, do you?
https://www.ssllabs.com/ssltest/analyze.html?d=api2.juvlon.com&hideResults=on&latest
Hello Sir
I had renewed certificate manually but i want to renew as auto renew we have 5-6 different domain i want to renew it auto before expire.
Ok, you need to find out if there is an ACME client installed on your machine.
try:
  • which certbot
  • history | grep certbot
  • history | grep api2.juvlon.com
How did you renew it? What software did you use? What commands did you run?
