Enable SSL auto-renewal
How do I enable SSL auto-renewal for my website?
Or consult a psychic?
Did your crystal ball also fall to the floor recently @rg305? Mine is broken too, so I can’t see all the missing information we require unfortunately :grin:
I tried reading between the lines but there was only the one line…
The added bio didn’t help much.
The somewhat twisted headshot seems like the start of a catfish episode.
At least we’ve got until Jan 30 01:29:55 2020 GMT to get to the bottom of this :grin:
My Website Address: https://afree.ir/
I enabled from within Cpanels
Is Activation Wrong?
Did you just "enable" Let's Encrypt? Or did you have to go through a lot of trouble to get the certificate? If you just "enabled/activated" Let's Encrypt, chances are it will auto-renew automatically without any human action. If you did go through a lot of trouble (i.e., manually got the certificate and uploaded said certifiate manually to cPanel), you'll have to repeat that step every 2-3 months (the certificates are 90 days valid and Let's Encrypt suggests to renew the certificate after 60 days).
I have no idea what you mean by that.
Hi @Angel
checking your domain there is no critical problem visible - https://check-your-website.server-daten.de/?q=afree.ir
The a.nic.ir name server is terrible, that's a known problem.
Your certificate
CN=afree.ir
	01.11.2019
	30.01.2020
expires in 63 days	afree.ir, mail.afree.ir, www.afree.ir - 3 entries
is valid, should be renewed in 35 - 45 days. So check your domain ~~2020-01-05 to see, if the automated cPanel renew has worked.
Oh, now the check is ready. There is an A+ G+M, that's good. So the site is on the Chrome- and FireFox-Preloadlist.
[offtopic] Do you actually think the thread starter has any idea what you mean by that? Actually, just reading your post - without actually surfing to your "website checker" - I have no idea why that piece about a.nic.ir is relevant..? And what the )#($*()# is an "A+ G+M" for an result? No clue.. No clue at all..
