Thanks for answering - The thing is that I am trying to figure out how it works - On a different web site I run, the perpetual renewal I think has been activated without any action on my end. I can see it because on the DNS there are several ACME challanges text (which I think they trigger renewal) and they have been set up automatically - In this web site I d like to have the same activation but I don’t understand how the automation is activated having done absolutely nothing to have automated on this other web site https://virtus-elementis.com/
I think that’s ultimately a question for your web host.
With shared hosting, the ACME automation/integration is usually done on the level of the hosting platform (cPanel or something else).
As such, only your web host would be able to tell you what’s available, and how you can use it.
It is a good sign, though, that your other website already has it activated. It suggests that you can quite likely get it enabled for all your sites. It’s just a question of finding out how.
Thanks! That’s correct, in fact once using ssslforfree, I was not enabled (as usual) to copy the bundle of the certificate onto the C panel ssl creation and I tried to upload it via FTP. After I requested my host provider to enable copying the bundle onto C panel and I was able to create it.
So, your guess is that when I tried to renew the certificate via ftp…this has triggered the auto renewal without any voluntary action on my end?
