Problema para instalar certificado
Hola estoi intentando instalar los certificados en mi plesk y me da este error
Mi dominio es:www.optimix.es
Imagen
Could not issue an SSL/TLS certificate for ziaruldesalaj.com
Details
Could not issue a Let's Encrypt SSL/TLS certificate for ziaruldesalaj.com . Authorization for the domain failed.
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/26530907270.
Details:
Type: urn:ietf:params:acme:error:dns
Status: 400
Detail: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.ziaruldesalaj.com - check that a DNS record exists for this domain
Hello @optimix Welcome to the forum.
Your site passes at least this test:
But I dont see a txt record for _acme-challenge.ziaruldesalaj.com in your DNS settings.
It may just be me.
Would you please give us as much information as possible so the incredible experts here can offer some assistance to you? It will certainly help a lot!
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. crt.sh | mydomain.com), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
https://certbot.eff.org/docs/
https://certbot.eff.org/docs/using.html#certbot-command-line-options
Also if you prefer another language to communicate can you please let us know so we can be of better assistance to you?
Estoy usando google translate y no parece estar ayudándome en este momento.
Hope I am helping!
