Issue failure after successful _acme-challenge
My domain is:*.dawn2dusk.uk
./acme.sh --server letsencrypt --issue --debug 2
-d '*.dawn2dusk.uk' --dns dns_nsupdate --log --force
It produced this output: [Wed May 25 15:53:45 UTC 2022] _on_issue_err
[Wed May 25 15:53:45 UTC 2022] Please check log file for more details: /root/.acme.sh/acme.sh.log
not relevant, using dns challenge (successful)
NetBSD-9.2
N/A
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): using acme.sh 3.0.4
Please show the log file. Currently there's nothing to go on unfortunately.
Also note that using --force usually doesn't help and has the potential to cause more harm than good, such as running into rate limits.
On a second note regarding rate limits: when something doesn't go exactly according to plan, it's better to switch over to the staging environment. Or even better: start with the staging environment until everything works and then switch over to the production environment. See Server · acmesh-official/acme.sh Wiki · GitHub for the parameters which can be used for the acme.sh --server option.
The domain has its nameservers hosted with GoDaddy.
How are you planning to update them with nsupdate? Shouldn't you be using acme.sh's GoDaddy support?
I don't see GoDaddy, I get:
dawn2dusk.uk    nameserver = viking.prd.co.uk
dawn2dusk.uk    nameserver = trafalgar.prd.co.uk
[maybe this was changed recently...]
Definitely changed. I saw GoDaddy dns too
Then...
We are making progress!
Looks like it took more than the oft-quoted 48 hours for changes to
propagate. I now have the cert. What I don't get is why the log file
reported success on the dns-update challenge and then the
_on_issue_error with no error code or explanation (it says look in the
log file, but there's nothing there).
The dns-update was presumably done to the correct DNS system.
While the external DNS challenge requests were being done against the old DNS system.
The "look in the log file" message is generic and is always a good place to look - but it can't possibly know everything that might have gone wrong outside of its' view.
None-the-less, glad to hear you are secure and automated!
Cheers :beers:
