Problem Creating ssl cert
My domain is:aproposhome.com
Could not issue an SSL/TLS certificate for aproposhome.com
Details
Could not issue a Let’s Encrypt SSL/TLS certificate for aproposhome.com . Authorization for the domain failed.
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/4585701209.
Details:
Type: urn:ietf:params:acme:error:dns
Status: 400
Detail: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.aproposhome.com - check that a DNS record exists for this domain
My web server is (include version):Ubuntu 18.04 x64
The operating system my web server runs on is (include version):Linux
My hosting provider, if applicable, is:Vultr
Based on this:
I would say, you clicked somewhere on the control panel to obtain a cert.
The failure makes sense; there is no TXT record there as expected:
nslookup -q=txt _acme-challenge.aproposhome.com
... can't find _acme-challenge.aproposhome.com: Non-existent domain
Has this type of request ever worked on this system?
What version of Plesk is it?
Who manages the host system?
