Error for Create Ssl certifact
My domain is: cruck.store
I ran this command: Its plesk server (i clic on install ssl)
translation
Unable to generate an SSL/TLS certificate for cruck.store
Details
Unable to issue Let's Encrypt SSL/TLS certificate for cruck.store. Domain authorization failed.
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/350779295287.
Details:
Type: urn:ietf:params:acme:error:dns
Status: 400
Detail: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.cruck.store - check that a DNS record exists for this domain
My hosting provider, if applicable, is: Plesk server on yorkhost --> version : 12.5
I can login to a root shell on my machine (yes or no, or I don't know): yes by ftp ssh is block
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): yes plesk 12.5
Welcome @CruckStore
Were you trying to get a cert for a wildcard name? Because Plesk used a DNS Challenge. Plesk SSL usually must be configured with a very specific DNS system to allow that to work. Are you hosting Plesk yourself or are you at a hosting service?
You could try getting a cert without a wildcard name. Often times they are not needed and just make it more complicated. For those an HTTP Challenge is used.
Your detailed error message
"challenges": [
            "type": "dns-01",
            "status": "invalid",
            "error": {
                "type": "urn:ietf:params:acme:error:dns",
                "detail": "DNS problem: NXDOMAIN looking up TXT for _acme-challenge.cruck.store - check that a DNS record exists for this domain",
                "status": 400
