No Idea how to renew my SSL certificate and it's becoming urgent
I can’t get in touch with my IT guy and I need to renew the SSL certificate on this domain ASAP. Does the security certificate get renewed on WP or the server?
My domain is: paragem.com.au
for bandaid fix:
call IT guy later as it would run out 3 mouth later.
thank you. Is it easy to install? do i need a plugin as the site is running WP? i have absolutely no IT skills!!!
you don’t install cert to WP, you install cert to webserver that runs the WP.
Therefore i need access to server?
yes you are, or a shard hosting system like Cpanel
Perfect - thank you so much for your help!
Hi @flyingblind
now you have a new certificate, created today:
CN=paragem.com.au
	24.06.2019
	22.09.2019
expires in 90 days
paragem.com.au, www.paragem.com.au - 2 entries
But your CT-log list shows an interruption ( https://check-your-website.server-daten.de/?q=paragem.com.au#ct-logs ):
CRT-Id Issuer not before not after Domain names LE-Duplicate next LE
1609266673 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-06-24 04:29:24 2019-09-22 04:29:24 paragem.com.au, www.paragem.com.au
2 entries duplicate nr. 1
1609230395 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-06-24 04:14:36 2019-09-22 04:14:36 paragem.com.au
1 entries duplicate nr. 1
1308530497 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-03-21 08:39:56 2019-06-19 07:39:56 paragem.com.au, www.paragem.com.au
2 entries
1327486093 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-03-21 08:27:16 2019-06-19 07:27:16 paragem.com.au
1 entries
The last certificate expired 2019-06-19, 5 days downtime.
How did you create that certificate?
Typical situation: A certificate should be renewed after 60 - 85 days (automatic). So you don't have such a downtime.
And you have two certificates, one only with one domain name. You don't need that certificate. Looks like there is a certbot or something else that has created two different certificates.
He was used old cert when I post few hours ago, and it seens he did call his IT guy to renew the cert I guess.
Yep. But then the renew didn't work, so it's not really a solution. And the wrong certificate (with only one domain name) could be removed. So both certificates are renewed.
thanks all. solution now sorted as we’re going to buy an SSL rather than relying on 3 month free certificates
