dxzn
1
My domain is: dxzn-smm.de
Hello I have a Problem when i go to CPanel and click Lets Encrypt SSL and choose dxzn-smm.de and www.dxzn-smm.de when i get the Error Message:
rg305
2
Hi @dxzn, welcome to the LE community forum
There seems to be an issue with the IPv6 access to your site:
curl -Iki4 http://www.dxzn-smm.de/
HTTP/1.1 200 OK
Content-Type: text/html
Content-Length: 336
Keep-Alive: timeout=15
Date: Mon, 13 Sep 2021 17:42:30 GMT
Server: Apache
Last-Modified: Tue, 03 Aug 2021 10:17:26 GMT
ETag: "150-5c8a4fe183e55"
Accept-Ranges: bytes
curl -Iki6 http://www.dxzn-smm.de/
HTTP/1.1 403 Forbidden
Connection: close
Cache-Control: no-cache
X-Frame-Options: SAMEORIGIN
X-XSS-Protection: 1; mode=block
X-Content-Type-Options: nosniff
Content-Security-Policy: frame-ancestors 'self'
Content-Length: 3447
Addresses: 2001:8d8:100f:f000::26a
217.160.0.111
217.160.0.111
rg305
4
Start with the outputs of:
curl -4 ifconfig.co
curl -6 ifconfig.co
sudo apachectl -t -D DUMP_VHOSTS
sudo netstat -pant | grep -i listen
[the problem is likely within the apache config]
