Issuance error "There was a problem processing your request"
Please I have this error message while trying to issue certificate on my domain.
I have WHM/CP linked to my VPS on Digital Ocean,
I have installed the lets encrypt on the server, but when i try to issue certificate i encounter this error message.
Error issuing certificate
Failed to issue certificate
Updating challenge for example.com: acme: error code 403 > "urn:ietf:params:acme:error:unauthorized": Invalid response from http://example.com/.well-known/acme-challenge/EcvtEpwTymwLXJpTqBIvTo8YZ8v3BbsFdZjzUlcOROw: "\n<html lang="en">\n\n<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />\n404 Not Fou" (order URL: https://acme-v02.api.letsencrypt.org/acme/order/51433791/313971378)
Any suggestion of how I get this fixed
Hi @alabius
we need some informations. Please answer the following questions:
Hi @alabius,
How is your cPanel server configured?
Requests to your server give a very atypical server banner and redirect:
$ curl -X GET -I <redacted>
HTTP/1.1 302 Found
Date: Wed, 13 Feb 2019 19:49:12 GMT
Server: Apache/2.4.18 (Ubuntu)
While it does appear to be a cPanel server, I’ve never seen anything like it. Ubuntu? cPanel can’t run on Ubuntu. Same with the redirect, not typical at all.
The way the cPanel plugin works is not complicated - It drops a file in your webroot (at least, what the cPanel server thinks your webroot is) and then an HTTP request is made to it.
If you are the root administrator, you can check in /usr/local/cpanel/logs/error_log to see what directory the challenge file was written to.
My domain is: ruffntumblekids.org
I ran this command: not clear. The process was initiated from cpanel
It produced this output: Above error
The operating system my web server runs on is (include version): Use Centos7 and Ubuntu 16.04 on my docker container
My hosting provider, if applicable, is: I run VPS
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): I use Cpanel 76.0.20 but have docker container
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): not sure
You are right. Changed the Port from 8080 to 80 because i had to use the port 80 with my docker container. But i have reverted it to 80. The server is using Centos7 while the ubuntu from your report is my docker container.
That may be incompatible.
Your main config looks ok ( https://check-your-website.server-daten.de/?q=ruffntumblekids.org ):
http://ruffntumblekids.org/
167.99.135.89 200 0.033 H
http://ruffntumblekids.org:81/ 200 1.030 H
http://www.ruffntumblekids.org/
167.99.135.89 200 0.047 H
https://ruffntumblekids.org/
167.99.135.89 302 http://ruffntumblekids.org:81/ 1.280 N
Certificate error: RemoteCertificateNameMismatch, RemoteCertificateChainErrors
https://www.ruffntumblekids.org/
http://ruffntumblekids.org/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
167.99.135.89 404 0.046 A
Not Found
http://www.ruffntumblekids.org/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
167.99.135.89 404 0.030 A
Not Found
Port 80 is open, /.well-known/acme-challenge sends the expected http status 404, if the file is unknown.
But:
A Info: Different Server-Headers found
http has only
Server: Apache
as header, http / port 81 and https have
cPanel is a closed world. So it may be impossible to create a certificate via cPanel if cPanel doesn't manage port 80 / http and the there-running webserver.
Yes, but i have changed the Apache port to 80 now.
Have even tried to install the Lets Encrypt on the docker container itself, but had the same issue
see error log below
There answers your cPanel with a http status 404.
These are different worlds.
