Problem processing my request
My domain is: r6hungary.hu
I ran this command: cpanel is run an automatical command
My operating system is (include version): Apache-verzió 2.4.25
My web server is (include version): cPanel verzió 62.0 (build 16)
I can login to a root shell on my machine (yes or no, or I don’t know): i don’t know
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): cpanel
Error issuing certificate
Failed to issue certificate
The Let’s Encrypt HTTP challenge failed: acme error ‘urn:acme:error:unauthorized’: Invalid response from http://r6hungary.hu/.well-known/acme-challenge/xN70pBwipiFUrgKcWaT88j_pkSjJRkdoj20-EQV-Nuk: " 404 Not Found
Not Found
<p"
hi @kopasz
can you outline which client you are using
there were some issues where the webroot and where the clients are putting the challenges is not the same
essentially you should be able to browse to http://r6hungary.hu/.well-known/acme-challenge/xN70pBwipiFUrgKcWaT88j_pkSjJRkdoj20-EQV-Nuk and recieve an application/text file type
Andrei
