Certbot gets 404 Not Found when trying to verify
I ran this command (domain.com and username were replaced):
/root/certbot-auto certonly --webroot -w /home/username/public_html -d www.domain.com -d domain.com
The client lacks sufficient authorization :: Invalid response from http://www.domain.com/.well-known/acme-challenge/5W1ceYO_tlwxt4QNcGasdf234324
There is no .htaccess file
CentOS release 6.8 (Final)
Server version: Apache/2.2.31 (Unix)
NA
Yes
NA
A test file in acme-challenge works OK:
curl -i domain.com/.well-known/acme-challenge/testfile
HTTP/1.1 200 OK
Date: Sun, 22 Jan 2017 17:08:55 GMT
Server: Apache
Last-Modified: Sun, 22 Jan 2017 17:08:19 GMT
Accept-Ranges: bytes
Content-Length: 20
Connection: close
Content-Type: text/plain
This is a test file
The error probably had more text than you’re showing us now, correct? I.e., 404, 403 or something like that.
Here is the whole thing:
/root/.local/share/letsencrypt/lib/python2.6/site-packages/cryptography/init.py:26: DeprecationWarning: Python 2.6 is no longer supported by the Python core team, please upgrade your Python. A future version of cryptography will drop support for Python 2.6
DeprecationWarning
http-01 challenge for www.mydomain.com
http-01 challenge for mydomain.com
Using the webroot path /home/username/public_html for all unmatched domains.
Waiting for verification…
Unable to clean up challenge directory /home/username/public_html/.well-known/acme-challenge
Failed authorization procedure. www.mydomain.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.mydomain.com/.well-known/acme-challenge/79El54TRfx5O1hLQBp8w7SYJIx3wTL-I_2ADNXcGM: "
404 Not Found
Not Found
<p", mydomain.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://mydomain.com/.well-known/acme-challenge/oNsANFJAoqlPt3BEDorT_ft9OZYf7jlXU: " 404 Not Found
Not Found
<p"
