ERROR whit dns problem on installing cert
My domain is: .robledomarketing.es / www.robledomarketing.es
I ran this command:sudo certbot --apache
1: robledomarketing.es
2: www.robledomarketing.es
blank to select all options shown (Enter ‘c’ to cancel): 2
tls-sni-01 challenge for www.robledomarketing.es
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Waiting for verification…
Failed authorization procedure. www.robledomarketing.es (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up A for www.robledomarketing.es
    Domain: www.robledomarketing.es
    Type: connection
    Detail: DNS problem: NXDOMAIN looking up A for
My web server is (include version): Apache/2.4.25 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu server 17.04
My hosting provider, if applicable, is: VPS OVH
I can login to a root shell on my machine (yes or no, or I don’t know):YES
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):NO
Are you sure that’s the correct domain? When did you register it? Who’s the DNS provider?
It doesn’t resolve in the DNS, and i don’t speak Spanish, but it looks unregistered on https://www.nic.es/ to me.
Indeed, I can confirm that nic.es says that robledomarketing.es is not a registered domain name.
