My domain is: http://pdede.sch.gr/
It produced this output: Which names would you like to activate HTTPS for?
1: pdede2.sch.gr
Renewing an existing certificate for pdede2.sch.gr
Domain: pdede2.sch.gr
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for pdede2.sch.gr - check that a DN S record exists for this domain
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for mo re details.
The operating system my web server runs on is (include version): Ubuntu Linux 18.04.1
see also: https://check-your-website.server-daten.de/?i=f50929fe-e820-40a4-8406-318dac2aa828
