Dear fellow Let’s Encrypt users,
Could you please help me with the error I am getting? I’ve checked the log in /etc/letsencrypt and it ends with the following error message:
Domain: www.falafeels.hero-translating.com
Type: connection
Detail: DNS problem: NXDOMAIN looking up A for www.falafeels.hero-translating.com
What should I change in my setup, so that the cert could be acquired? In my DNS setup - falafeels.hero-translating.com has an A record pointing to 95.80.200.32.
falafeels.hero-translating.com has an A record pointing to 95.80.200.32 but www.falafeels.hero-translating.com doesn't have an A record. You should add it in your DNS Server... the same you did for falafeels.hero-translating.com but this time for www.falafeels.hero-translating.com.
In this case @rg305 meant adding a subdomain of the subdomain. If you can only add one level of subdomain, that’s a limitation in the interface.
By the way, if you can’t add the A record here, the www form would not work in a browser anyway even via unencrypted HTTP (regardless of the issuance of the certificate).
So @sahsanu’s advice makes sense: you can ask the DNS provider, or whoever created this form. If the form really only allows you to add a single level of subdomain, it’s not adequate for doing what you want to do here.
One thing to try first could be to enter www.falafeels in the box as new the name to add. It might be a little confusing, but perhaps this form already allows you to add a subdomain of a subdomain that way. There’s no way to predict this without trying it.
It is a subdomain of hero-translating.com. However, the host still needs to allow creating a subdomain of a subdomain here, which it's still not clear if they do or not.
@schoen@rg305@sahsanu@bytecamp@honzakuchar
Thank you all for your suggestions. I have contacted the provider and will let you know how it develops once I have their response!
