Error with DNS using Certbot
www.compra-mascarillas.com, www.tuwebsite.co, www.u-bunny.com
certbot --apache
Enabled Apache rewrite module
Challenge failed for domain www.compra-mascarillas.com
Challenge failed for domain www.tuwebsite.co
Challenge failed for domain www.u-bunny.com
http-01 challenge for www.compra-mascarillas.com
http-01 challenge for www.tuwebsite.co
http-01 challenge for www.u-bunny.com
Ubuntu 18 ( Bionic )
Windows10
no
certbot 1.8.0
my domains are hosted on Namecheap, I have the following records for each of the three domains:
A / @ / 45.82.167.208
AAAA / @ / 2001:ac8:20:6b::6eb4:2a07
Please read the error messages provided by the Let's Encrypt validation server. And compare those error messages with the DNS zone settings you've pasted above. The issue should be obvious.
I am no expert, I cant see why it is not working. Can you be more specific ?
Thanks for your answer
You don't have the www subdomain defined in your DNS zone.
Hi @Simplecoded
checking your domain now, there is no A record with the www you have used in your command - https://check-your-website.server-daten.de/?q=compra-mascarillas.com
Host Type IP-Address is auth. ∑ Queries ∑ Timeout
compra-mascarillas.com A 45.82.167.208 Frankfurt am Main/Hesse/Germany (DE) - M247 Ltd Hostname: setzer.es yes 1 0
AAAA 2001:ac8:20:6b::6eb4:2a07 Frankfurt am Main/Hesse/Germany (DE) - M247 Ltd yes
www.compra-mascarillas.com Name Error yes 1 0
The non-www has A/AAAA, the www has not. So creating a certificate with the www subdomain via http validation can't work.
But there is an older check:
compra-mascarillas.com A yes 1 0
AAAA yes
www.compra-mascarillas.com A 45.82.167.208 Frankfurt am Main/Hesse/Germany (DE) - M247 Ltd Hostname: setzer.es yes 1 0
There the www version has all, the non-www version has nothing.
Combine both versions.
I just added the last two. That should do the trick ?
Thank you
Yes, now the main domain and the www subdomain have the same A- and AAAA-records. Same with your other domains (didn't checked).
