DNS problem: NXDOMAIN looking up A
My domain is: desbiens-desmeules.com
I ran this command: $ sudo certbot --apache
3: desbiens-demeules.com
4: www.desbiens-demeules.com
blank to select all options shown (Enter 'c' to cancel): 3 4
http-01 challenge for desbiens-demeules.com
http-01 challenge for www.desbiens-demeules.com
Failed authorization procedure. desbiens-demeules.com (http-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up A for desbiens-demeules.com - check that a DNS record exists for this domain, www.desbiens-demeules.com (http-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up A for www.desbiens-demeules.com - check that a DNS record exists for this domain
**IMPORTANT NOTES:**
Domain: desbiens-demeules.com
Type: None
Detail: DNS problem: NXDOMAIN looking up A for
domain
Domain: www.desbiens-demeules.com
Type: None
domain
My web server is (include version): Apache/2.4.38 (Debian)
Distributor ID: Debian
Description: Debian GNU/Linux 10 (buster)
Release: 10
Codename: buster
My hosting provider, if applicable, is: Own VPS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.31.0
Here's what I've tried:
  1. DNS records
@ 10800 IN SOA ns1.gandi.net. hostmaster.gandi.net. 1587317265 10800 3600 604800 10800
@ 10800 IN A 199.58.81.174
@ 10800 IN MX 10 spool.mail.gandi.net.
@ 10800 IN MX 50 fb.mail.gandi.net.
blog 10800 IN CNAME blogs.vip.gandi.net.
imap 10800 IN CNAME access.mail.gandi.net.
pop 10800 IN CNAME access.mail.gandi.net.
smtp 10800 IN CNAME relay.mail.gandi.net.
webmail 10800 IN CNAME webmail.gandi.net.
www 3600 IN CNAME desbiens-demeules.com.
  1. Firewall
    sudo ufw allow 443
  2. Tested default-ssl.conf
  3. Verify DNS
    https://check-your-website.server-daten.de/?q=desbiens-desmeules.com
    https://letsdebug.net/desbiens-desmeules.com/373115
Many thanks for your help! :smiley:
Your Apache is configured for desbiens-demeules.com and not for desbiens-desmeules.com.
Please correct your Apache configuration to reflect the correct domain name and try again.
Also, your www subdomain CNAME in the zone file points to the incorrect hostname in your information above, while it is actually pointing to the correct hostname in the actual DNS zone file. Another typo?
Seriously oh goodness. Thanks for the second eyes. I saw all the other typo errors on the forum and thought I had totally verified! Working now, many thanks!
