Govind
1
Hello ,
i am getting this error when i am executing the certbot command :
Domain: www.govindbairwa.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for www.govindbairwa.com
My dns is working fine , my dns configuration is below :
$TTL 86400
@ IN SOA dns.govindbairwa.com. root.govindbairwa.com. (
2019071005 ; serial
3600 ; refresh
1800 ; retry
604800 ; expire
86400 ) ; minimum
@ IN NS www.govindbairwa.com.
@ IN A 192.168.0.99
www IN A 192.168.0.99
please help me.
danb35
2
No it isn't:
Dans-MacBook-Pro-4709% dig www.govindbairwa.com
; <<>> DiG 9.8.3-P1 <<>> www.govindbairwa.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 47455
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
;; QUESTION SECTION:
;www.govindbairwa.com. IN A
;; AUTHORITY SECTION:
com. 900 IN SOA a.gtld-servers.net. nstld.verisign-grs.com. 1573107217 1800 900 604800 86400
;; Query time: 49 msec
;; SERVER: 192.168.1.1#53(192.168.1.1)
;; WHEN: Thu Nov 7 01:13:53 2019
;; MSG SIZE rcvd: 111
Dans-MacBook-Pro-4709% dig ns govindbairwa.com
; <<>> DiG 9.8.3-P1 <<>> ns govindbairwa.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 35077
;govindbairwa.com. IN NS
com. 900 IN SOA a.gtld-servers.net. nstld.verisign-grs.com. 1573107282 1800 900 604800 86400
;; Query time: 41 msec
;; WHEN: Thu Nov 7 01:14:57 2019
;; MSG SIZE rcvd: 107
Edit: That's no doubt because neither you nor anyone else owns that domain:
Govind
3
this is all , in my local network … i am not using it publicly.
danb35
4
It doesn't matter if you're using it publicly, you must own a public domain and publish public DNS records in order to get a cert from Let's Encrypt.
Govind
5
OK Dude , Got it , thanks.
