Certbot NGINX, DNS problem: NXDOMAIN looking up A
Fail in a domain and subdomain that is working online (!). How to say to certbot that it is valid? No problem with IP or A names, or CNAMEs, no problem with NGINX scripts.
tls-sni-01 challenge for www....
Failed authorization procedure. xpto.myDomain1 (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up A for xpto.myDomain1, abcd.myDomain1 (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up A for abcd.myDomain1, xyz.myDomain1 (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up A for xyz.myDomain1, .....
   Domain: xpto.myDomain1
   Type:   connection
   Detail: DNS problem: NXDOMAIN looking up A for xpto.myDomain1
   Domain: abcd.myDomain1
   Type:   connection
   Detail: DNS problem: NXDOMAIN looking up A for abcd.myDomain1
   Domain: xyz.myDomain1
   Type:   connection
   Detail: DNS problem: NXDOMAIN looking up A for xyz.myDomain1
   Domain: ....
Hi @ppKrauss,
It won't be possible to help you without knowing the domain names that are failing. Can you share those?
Sorry @cpu, was my mistake, was new names with no CNAMEs… As soon as I registered the CNAMES in the domain, the certbot certificate was produced.
PS: delete the question?
Hi @ppKrauss,
Glad you got it sorted out!
I'd prefer not to delete the question since it might be helpful to someone in the future :slight_smile:
Thanks @cpu. Perhaps need an issue ticket, “NXDOMAIN looking up A” is a wrong message, “NXDOMAIN looking up A or CNAME” is better. The solution in trivial case as mine is
  • add new (need for) CNAME or
  • delete the (expurious) Nginx server-rules for that non-existent server-name.
