DNS problem: NXDOMAIN looking up A
My domain is: shinyserv.es
I ran this command: sudo letsencrypt certonly -a webroot --webroot-path=/var/www/html/ --domain shinysrv.es
http-01 challenge for shinysrv.es
Using the webroot path /var/www/html for all unmatched domains.
Challenge failed for domain shinysrv.es
   Domain: shinysrv.es
   Type:   dns
   Detail: DNS problem: NXDOMAIN looking up A for shinysrv.es - check
   that a DNS record exists for this domain
My web server is (include version): nginx/1.18.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: Amazon Route 43
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.40.0
I attach the records of the Hosted Zone that I added following this guide:
This domain doesn't appear to be registered.
Did you mean to type shinyserv.es in your Certbot command?
Ah, that's gotta be a classic, the good old typo on the command line :laughing:
Yes, my bad, wrong typing... Thank you! Now I get different errors that I need to check out :slight_smile:
Good luck! I hope you manage to fix the next hurdle. If you don't manage to figure it out yourself, you're always welcome here.
