I ran this command
sudo certbot-auto certonly --standalone
-d hr.dynamicflowsystems.com -d www.hr.dynamicflowsystems.com
-------and got this
http-01 challenge for hr.dynamicflowsystems.com
http-01 challenge for www.hr.dynamicflowsystems.com
Waiting for verification…
Challenge failed for domain hr.dynamicflowsystems.com
Challenge failed for domain www.hr.dynamicflowsystems.com
_az
November 3, 2019, 9:15pm
2
This subdomain doesn't exist. If you'd like to use it, you need to add it in your GoDaddy DNS interface first.
The second issue here is that you are using --standalone, which is intended for users who don't have a webserver.
You have Apache as an existing webserver, so you should use --apache instead of --standalone.
hr.dynamicflowsystems.com is exist
and for apache it had to started on web server ubuntu server
_az
November 3, 2019, 9:49pm
4
But the www. variant doesn't, which is the cause of the first error.
I'm not sure what you mean. --standalone is not suitable if you have a webserver running.
Yes i have web server running
After writing --apache
----------- I had run command
hbadaya@testubuntu:~$ sudo certbot-auto certonly --apache -d hr.dynamicflowsystems.com -d www.hr.dynamicflowsystems.com
-------i got
Enabled Apache rewrite module
Code ran
output
Hi @harshitbadaya
there is a check of your domain - 1,5 hours old - https://check-your-website.server-daten.de/?q=hr.dynamicflowsystems.com
Host
T
IP-Address
is auth.
∑ Queries
∑ Timeout
A
104.210.11.74 Ashburn/Virginia/United States (US) - Microsoft Corporation No Hostname found
0
AAAA
Where is your Certbot running? On that ip address? 104.210.11.74?
If not, that can’t work.
Letsencrypt checks that ip to find the validation file.
If you use that ip, what says
apachectl -S
There is an ERP-system running. May be that blocks Certbot.
what can we do for fix this ?
any other solution?
After running this Command
$ apachectl -S
Got this –
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 10.0.1.5. Set the ‘ServerName’ directive globally to suppress this message
VirtualHost configuration:
*:80 10.0.1.5 (/etc/apache2/sites-enabled/000-default.conf:1)
ServerRoot: “/etc/apache2”
Main DocumentRoot: “/var/www/html”
Main ErrorLog: “/var/log/apache2/error.log”
PidFile: “/var/run/apache2/apache2.pid”
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name=“www-data” id=33 not_used
Group: name=“www-data” id=33 not_used
