Problem with installing letsencrypt on subdomain
My domain is:test.frequenz-messung.de
I ran this command: sudo certbot certonly --standalone --preferred-challenges http --http-01-port 80 -d test.frequenz-messung.de -d www.test.frequenz-messung.de
It produced this output:Failed authorization procedure. www.test.frequenz-messung.de (http-01): urn:ietf :params:acme:error:dns :: DNS problem: NXDOMAIN looking up A for www.test.freque nz-messung.de
    Domain: www.test.frequenz-messung.de
    Type: None
    Detail: DNS problem: NXDOMAIN looking up A for
The operating system my web server runs on is (include version): Apache/2.4.18 (Ubuntu)
My hosting provider, if applicable, is:netcup.net
I can login to a root shell on my machine (yes or no, or I don’t know):Yes
It’s true. There’s a DNS record for test.frequenz-messung.de., but www.test.frequenz-messung.de. does not exist.
test.frequenz-messung.de. 300   IN      A       193.30.120.186
You need to add DNS record(s) at your DNS service before you can use HTTP-01 validation.
But i only have one domain. How can i add another DNS record for www.test.frequenz-messung.de. ??? and what kind of record should i add
You asked Certbot to get a certificate for two names, test.frequenz-messung.de and www.test.frequenz-messung.de.
You should add an A record with the same value as your other one, probably the same way you added it.
Edit: Or, you can get a certificate for only the one, existing name.
Yeah but when add one also i end up with an error
Failed authorization procedure. test.frequenz-messung.de (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://test.frequenz-messung.de/.well-known/acme-challenge/ac_MF_4LWjiodhUrfnW747v3kYVRdYFz9C13D3-ehOk: Timeout during connect (likely firewall problem)
    Domain: test.frequenz-messung.de
    Type: connection
    Detail: Fetching
I can’t access http://test.frequenz-messung.de/ either. Can you?
Maybe there’s a firewall blocking all connections, or connections from foreign countries?
I do have firewall but all traffic is allowed on my IP
"INPUT -p tcp --dport 80 -m state --state NEW -s 192.68.16.1/32 -j ACCEPT "
or maybe i need another rule hmmm
That only allows traffic coming from 192.68.16.1. The rest of the Internet is blocked.
Upss sorry figured out whats the issue, thank you so much for your help @mnordhoff
