Cleaning up challenges Some challenges have failed. Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details
My domain is:mydomain.com (it is from github)
I ran this command:sudo certbot -v certonly --register-unsafely-without-email --agree-tos -d mydomain.com
It produced this output:Hint: The Certificate Authority failed to verify the temporary nginx configuration changes made by Certbot. Ensure the listed domains point to this nginx server and that it is accessible from the internet.
The operating system my web server runs on is (include version):vm kali linux - 2.4.54 (debian)
My hosting provider, if applicable, is: windows host
Hello @Abad, welcome to the Let's Encrypt community. :slightly_smiling_face:
Let’s Encrypt offers Domain Validation (DV) certificates.
Domain names for issued certificates are all made public in Certificate Transparency logs.
Thus you need to own and have control over the Domain Name you wish to obtain a certificate for,
from an ICANN Accredited Registrar.
For Let’s Encrypt to issue a Domain Validation (DV) certificate Domain Validation must happen
and it is a CA/Browser Forum Baseline Requirement.
Best Practice - Keep Port 80 Open
What IP addresses does Let’s Encrypt use to validate my web server?
Let’s Encrypt does not publish a list of IP addresses we use to validate,
and these IP addresses may change at any time.
Let's Encrypt uses Multi-Perspective Validation Improves Domain Validation Security - Let's Encrypt
Since these are Domain Validation (DV) certificates the Domain Name System (DNS) is used extensively in the validation process as well a allowing us to assist here on Let's Encrypt community.
DNS Queries need to give consistent results from any location on the Internet, all your authoritative DNS Servers for the Domain need to also give consistent results as well.
Testing and debugging are best done using the Staging Environment as the Rate Limits are much higher. Rate Limits are per week (rolling).
And to assist with debugging there is a great place to start is Let's Debug.
:arrow_down: :arrow_down: :arrow_down: :arrow_down: :arrow_down: :arrow_down: :arrow_down: :arrow_down: :arrow_down: :arrow_down: :arrow_down: :arrow_down: :arrow_down: :arrow_down: :arrow_down: :arrow_down: :arrow_down:
Thank you for assisting us in helping YOU!
My domain is: massage-spa.herokuapp.com
This is what your current certificate has:
Your site is on Heroku, which already provided a cert for it (under their domain):
Your site is passing SSL Server Test: massage-spa.herokuapp.com (Powered by Qualys SSL Labs)
What issue(s) are you trying to get solved?
The real website is mydomain.com I got this form github I’m trying to learn please help meee !!!
https://www.mydomain.com/ is a Domain Registrar and Web Hosting company as shown here: Whois mydomain.com
This doesn't seem quite right to me. Are you using their services?
Clicking the help button on their site might be your best bet.
This is what I see pressing the help button.
