DNS problem: www.domain.com and domain.com
I have problem when i comment
./letsencrypt-auto --config /etc/letsencrypt/configs/domain.tld.conf certonly
domain = gen01.tel4vn.com
http-01 challenge for gen01.tel4vn.com
Using the webroot path /var/www/letsencrypt for all unmatched domains.
Waiting for verification…
Failed authorization procedure. gen01.tel4vn.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://gen01.tel4vn.com/.well-known/acme-challenge/lIMQ9p0YFSZjZu7jjo7Vyojc7ZQDlYZVeQAvX1wb2HM: "
404 Not Found
404 Not Found
WHEN I CONFIGURE domain = www.gen01.tel4vn.com
Failed authorization procedure. www.gen01.tel4vn.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up A for www.gen01.tel4vn.com
    Domain: www.gen01.tel4vn.com
    Type: connection
    Detail: DNS problem: NXDOMAIN looking up A for www.gen01.tel4vn.com
root@debian:/opt/letsencrypt# lsb_release -da
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 8.9 (jessie)
Can i help u check it? Thank you very much
I’m come from Vietnam
You need to create a record with www and @ that points to your server IP.
How i do that?
Can u help me?
That all depends on your DNS provider. Each one will have a different way of going about that. Do you know who your DNS provider is? If it’s one that anyone here is familiar with, we can help for sure. If not, you might need to ask their support if your unsure of how to do this on their interface.
I can. It’s generally the same process for all DNS providers, but it would make it easier if you told us what DNS provider you use.
