Detail: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.deep-find.com
My domain is: deep-find.com www.deep-find.com
certbot certonly --manual --preferred-challenges dns --server https://acme-v02.api.letsencrypt.org/directory -d deep-find.com
dns-01 challenge for deep-find.com
NOTE: The IP of this machine will be publicly logged as having requested this
certificate. If you’re running certbot in manual mode on a machine that is not
your server, please ensure you’re okay with that.
Are you OK with your IP being logged?
(Y)es/(N)o: Y
Please deploy a DNS TXT record under the name
_acme-challenge.deep-find.com with the following value:
0Zz9Fgw0dQ4PEri7S_BJ-nha1opl-mskMpnpxtw1hqs
Before continuing, verify the record is deployed.
Press Enter to Continue
Waiting for verification…
Failed authorization procedure. deep-find.com (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.deep-find.com
    Domain: deep-find.com
    Type: None
My web server is (include version): nginx/1.10.3 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 16.04.5 LTS
My hosting provider, if applicable, is: google domains
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
I’m already checked records of my domain.
Also I waited full time to verify the record is deployed :frowning:
Did you remove that record after challenge failure?
I can’t really find that record via dig or nslookup or anything similiar.
Also, how long did you wait before you proceed with the validation?
Thank you
How did you check?
The check I ran returned "empty".
nslookup -q=txt _acme-challenge.deep-find.com
No, I did not remove the record.
I waited about 5 minutes.
In my google domain services.
Is there any other ways to check the acme-challenge records?
Is that record still present?
Since we really can't find it.
You could use something like https://www.whatsmydns.net/ , https://unboundtest.com/ or Network Tools: DNS,IP,Email to check your TXT records.
Thank you
Also, can you confirm that you've added the TXT record onto _acme-challenge.deep-find.com?
Thank you
Can see it this time …
$ dig +noall +answer _acme-challenge.deep-find.com txt
_acme-challenge.deep-find.com. 3599 IN  TXT     "sreuDEwLay1oB14AcGrWb_ZsmGq088oQ7TOwQTEJ7B8"
OMG. I’ve wrote wrong record name!
Thanks for help to find errors.
aww…
Congrats
