DNS problem: NXDOMAIN looking up TXT for
Attempted:
certbot certonly -a manual --preferred-challenges dns -d subseasolutions.net -d www.subseasolutions.net
Results:
dns-01 challenge for subseasolutions.net
dns-01 challenge for www.subseasolutions.net
NOTE: The IP of this machine will be publicly logged as having requested this
certificate. If you’re running certbot in manual mode on a machine that is not
your server, please ensure you’re okay with that.
Are you OK with your IP being logged?
(Y)es/(N)o: y
Please deploy a DNS TXT record under the name
_acme-challenge.subseasolutions.net with the following value:
q_Iehior2uERZwrZ-wx5f8lLoX9D9T-Z4BqyIpIZO3g
Before continuing, verify the record is deployed.
Press Enter to Continue
_acme-challenge.www.subseasolutions.net with the following value:
8LEBJofPi33j33ExL7tQN8To5kO2iSJg6JQRB0P2m_0
(This must be set up in addition to the previous challenges; do not remove,
replace, or undo the previous challenge tasks yet. Note that you might be
asked to create multiple distinct TXT records with the same name. This is
permitted by DNS standards.)
Waiting for verification…
Failed authorization procedure. subseasolutions.net (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.subseasolutions.net, www.subseasolutions.net (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.www.subseasolutions.net
Domain: subseasolutions.net
Type: None
Detail: DNS problem: NXDOMAIN looking up TXT for
Domain: www.subseasolutions.net
Type: None
NOTE: I did add the TXT records to the DNS prior to attempting this.
Any help appreciated!
Did you enter those records inside your GoDaddy DNS?
Thank you
Hi @glapalomento
I can't see your txt records:
TXT - Entries
Domainname TXT Entry Status ∑ Queries ∑ Timeout
subseasolutions.net v=spf1 a:dispatch-us.ppe-hosted.com ~all ok 1 0
subseasolutions.net ppe-282374e8a9c2b6e231d3 ok 1 0
www.subseasolutions.net v=spf1 a:dispatch-us.ppe-hosted.com ~all ok 1 0
www.subseasolutions.net ppe-282374e8a9c2b6e231d3 ok 1 0
_acme-challenge.subseasolutions.net Name Error - The domain name does not exist 1 0
_acme-challenge.www.subseasolutions.net Name Error - The domain name does not exist 1 0
_acme-challenge.subseasolutions.net.subseasolutions.net Name Error - The domain name does not exist 1 0
_acme-challenge.www.subseasolutions.net.www.subseasolutions.net Name Error - The domain name does not exist 1 0
You have txt entries. But not the required versions. _acme-challenge.subseasolutions.net and _acme-challenge.www.subseasolutions.net are required.
You didn't create typical wrong entries (the last two), this is good.
Sorry, but I did enter them but I removed them since trying. I will do it again so you can test. Thank you!
OK, I tried it again and got same results. This time I have left the TXT entries in the Godaddy acct.
XkuohdHqYLDCYxkFBLF7t1jWqCe8EI60a1sSnpARZrU
sUIQgdUdUrENlG3k897WsMFqchWTf6DNEBF3GLfzLxY
    Type: None
    Type: None
Now it's the wrong domain name (using subseasolutions.net - Make your website better - DNS, redirects, mixed content, certificates ):
TXT - Entries
_acme-challenge.subseasolutions.net.subseasolutions.net XkuohdHqYLDCYxkFBLF7t1jWqCe8EI60a1sSnpARZrU perhaps wrong 1 0
You have created one entry with _acme-challenge.subseasolutions.net.subseasolutions.net.
So your context adds your domain name. So add only _acme-challenge and _acme-challenge.www as domain name.
Oh, wow. I was basically just copying the line and didn’t realize I needed to leave the domain off. Thanks so much. This is now resolved.
You would think that all large scale DNS systems would have logic programed in that can check for such situations; and ask for you to reconfirm.
Are you sure you want to add record: _acme-challenge.subseasolutions.net.subseasolutions.net
[The new record would contain the domain twice]
But hey it’s only (almost) 2019 - machines have not acquired intelligence yet - LOL
